Piston Question
    Well... the motor is still purring along, but the tranny bit the dust I guess?!? I'm assuming I bent a shift fork somehow. It messed up while I was just putting around town. (HONEST!) It wouldn't shift down to neutral or 1st.
    I rode it today again since my son in college has my car. On my way home from work, I downshifted to second pulling onto my road... and there it stays. No up or down.
    So as I prepared to marry more used parts together to make something that runs, the machinist calls and says my cylinders are done. I had them bored and honed.
    So... looks like I now begin the 1179 rebuild on the first motor.
    Have I mentioned how incredibly tired I am of pulling this %$#* thing apart? This will be the 4th time I think in the last 2 months. Maybe this will get me by for a while... I hope.
      • 7819
      Tod,
      Do a search BEFORE you tear into it too much. You may have a problem on the outside of the tranny, in the shift linkage. If you pull the left cover, after removing the gear selector, you may find the problem...
        I'll do a search on it after I get it out... but I'm already building this other motor to just do a swap.
        I also took an extra head to my machinist to have some porting work done and a 3 angle valve job. He's going to open up the intake ports a bit and even move the valve seat out towards the edge of the valve face some to get a little more air through. He's going to clean up the cast marks some, but will leave a bit to help atomize the fuel and prevent any air dams or pooling (He explained them to me but don't ask! lol)
        I didn't mention my thoughts about it, but he saw the YICS ports on the head and asked about them. I told him they'd be capped off. He looked them over and said what I have always wondered about... "Man, those would make some great spots to put nitrous on!"
        Don't think I'm not tempted! lol. I told him to take his time on the head since I'm going to run the stock one first. But I'll eventually have to slap it on and see if there's a difference.
          Also... I can get them, but man those litle circlips for the pistons are a PITA! Anyone know a trick to them? Seems about every third try sends one shooting across the room.
          • 79XS11F
            • Jul 2006
            • 3563
            • Ottawa, Ont. Canada
            #35
            I forced mine in with the open end directly across from the notch for removing them. I put the open end in first and used a small screw drive to lever them in using the notch as a place to get the leverage. They popped right in. I kept my finger over them so they went in instead of out.
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
