Doesn't drop back to idle right away...???
  • Hammerhead1st
    XStremely XSive(Deceased)
    • Jul 2007
    • 330
    • Lawrencvile, GA
    Ok...synch'd the carbs in prep for the Syracuse meet n greet, and suddenly, the bike wont drop back to idle right away. Instead, it seems to hang at high r's for a few secs, then drops back to idle.
    All the mix screws are set at 1 1/2 out, all carbs are synch'd damn near perfectly. Thought it might be a sticky throttle issue, but no, it isnt. Any ideas?
    "Rat Rod"
    79 XS1100 Standard
    87 VMAX cans
    Cheap Japanese Tires
    Cobalt Blue Rattle Can Paint
    Custom Lighting on a Budget
    Perry Center Fire Department
    Perry Emergency Ambulance
    "If we don't do it, who will?"
    Some people have one of those days, I have one of those lives...
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    Check for a vacuum leak. Probably with your 25 year old vacuum port caps from when you synch'ed her.
    • Hammerhead1st
      • Jul 2007
      • 330
      • Lawrencvile, GA
      I replaced the caps last month with brandy-new ones, but will check for leaks anyhow...Thanks man.
      "Rat Rod"
      79 XS1100 Standard
      87 VMAX cans
      • blue giant
        • Aug 2007
        • 880
        • Ontario, Canada
        I had a similiar problem last weekend when I synced mine, turned out I wasn't synced at all, one of the butterflies (Carb #4) was closing sooner than the rest causing the idle to hang up. Sometimes a blip of the throttle would bring down, sometimes not. I didn't find the problem until I removed he carbs and could visually see what was happening.
        Hope this helps,
        Paul
        Paul
        1983 XJ1100 Maxim
        1979 XS1100 Standard
        1980 XS1100 Special
        • Hammerhead1st
          • Jul 2007
          • 330
          • Lawrencvile, GA
          Paul,
          How'd you fix it? Pre-synch?
          "Rat Rod"
          79 XS1100 Standard
          87 VMAX cans
          • blue giant
            • Aug 2007
            • 880
            • Ontario, Canada
            Originally posted by Hammerhead1st
            Paul,
            Yes, the wire twist tie method.!
            Worked very well too.
            Paul
            Paul
            1983 XJ1100 Maxim
            1980 XS1100 Special
            • Crazcnuk
              • 2980
              • Hinton, AB, Canada
              I had the same problem, and it was the throttle cable. It had started breaking up at the throttle grip.
              It broke a couple days later.
              '05 ST1300
              • xsilerating
                • Dec 2006
                • 430
                • Eastern Ontario, Canada
                You may want to try turning down your fast idle screw - just a tad - your adjustments may have resulted in a very slight increase on the 'rich' side.
                I've had this happen a couple of times, the last after a mechanic adjusted the carbs for me.
                Ron
                1980 XS11 LG (Diablo)
                1980 XS11 G (Bagger)
                1978 XS11 G (White Knight)
                1978 XS11 G (Skeleton)
                2016 SS (S.S. Flyer)
                • AlanB
                  • Oct 2006
                  • 705
                  • Scotland
                  Hi Hammerhead,
                  Still sounds like a synch problem....... What did you use to synch 'em?
                  I have had problems with almost every set of "Gauge-type" balancers I have tried........... If you use "gauges", try swapping 'em onto different cylinders after you have finished; The results can be quite illuminating!
                  AlanB
                  If it ain't broke, modify it!
                  • 79XS11F
                    • 3563
                    • Ottawa, Ont. Canada
                    If the throttle cable is not sticking and adjusted properly then check for smooth operation of the butterfly valves and if their good then you most likely have a air leak to find and plug.
                    Rob
                    KEEP THE RUBBER SIDE DOWN
                    1978 XS1100E Modified
                    1978 XS500E
                    1979 XS1100F Restored
                    1981 Suzuki GS1100
                    1983 Suzuki GS750S Katana
                    1983 Honda CB900 Custom
