Another carb ID needed
  • 81xsproject
    • 3185
    • Fortuna, CA
    I have some XS carbs that have later style bodies, brass floats, push-in seats, and are jetted with 115 and 120 mains. Mainly need to know what the proper float heights should be.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
  • mro
    • Oct 2005
    • 4276
    • Hayward, California
    would bet 23mm
    mro
    • egsols
      • Jan 2006
      • 1090
      • Barrie, Ontario, Canada
      Didn't they use the brass on the 78 and 79 and the plastic on the 80 and 81? 78-79 I think floats were 25.7mm and 23mm 80-81. Wierd though the jets sound like 80-81.
      Ernie
      • John
        • 5117
        The floats are probably some that were swapped because the 80-81 carbs did have the plastic floats. I have put plastic floats in the 78 carbs on my 80. I set them to 23mm, as per the spec for the 80-81.
        • mro
          • Oct 2005
          • 4276
          originally post by John
          Would not of thought plastic/brass floats would change float spec height. Weird that when I changed a set out of a 79 special and set em to 25.7mm bike ran fine.
          mro
          • 81xsproject
            • 3185
            • Fortuna, CA
            I forgot to mention that they also have the bolt drain bowls of the old style instead of the screw drain.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
            • ccogswel
              • Jun 2005
              • 302
              • Bowling Green, Ky
              I thought the 80-81 carbs had the push in seats?
              The brass floats would be for the 78-79 carbs.
              I could be wrong.
              Chris
              79 XS1100 Standard aka: Mutt
              Gimme Fuel Gimme Fire!
              • petejw
                • 2269
                • sydney australia
                If the bodies are late model
                id set the floats at 23mm and go from there. :-)
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                1981 xs1100 RH (aus) (5N5)
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
