In the tech tips, I was reading Blaines Carb FAQ and saw this:
What I am wondering, is if anyone knew what the correct measurement of the spring was supposed to be when new. I was thinking of buying one brand new (still available at around $14) and posting the info. Money is tight right now though and SWMBO has forbid the purchasing of moto-parts
. If no one knows, I will do it in the not too distant future.
Q: What about the springs that push the slides down? Do they wear out? A: The short answer is that stiffer springs seem to cause the mixture to be leaner and softer springs seem to be richer. I believe they do soften up over time and I think it's important that all four carbs have matching springs. Here is my experiment:
I have several XS650 carbs as well as XS11 carbs. Many of the parts are interchangable. I noticed that the XS650 slide springs are about 10mm shorter than the XS11 springs (both from '80 models). I have been fighting an "off idle" stumble on the XS11 since I've owned the bike. I got to thinking that shorter springs would let the slides open quicker and probably improve the performance (WRONG!) -- it's a good thing I had the shorter 650 springs to try instead of cutting my XS11 springs shorter. I discovered, to my surprise, that the engine didn't run well at all with the shorter springs - it wouldn't take any throttle, just sort of gagged on it unless opened very gradually - it seemed to exaggerate the problems I had been having before. So, I decided to try lengthening the springs instead and started wondering how much tension they might have lost being compressed for 20 years. I carefully stretched the stock springs out about 8mm longer and reassembled the carbs. It accepts the throttle much better than it ever has. NOTE: my bike has low restriction air filters and exhaust and perhaps this is unique to my setup and not something required on a stock system. My impression is that the springs had softened over time and were allowing the slides to lift too quickly, causing an overly rich mixture at low rpms - but it may just mean my exhaust setup requires slightly stiffer springs than stock.
