hey, I just re and re'd my clutch (took it out to clean, etc) and here is the problem....
Start the bike in neutral (no problem), go to put it in 1st or 2nd, it stalls out right away. I also noted that when the bike is in gear, it remains in gear (even with the clutch lever pulled) and won't roll freely until it's shifted to neutral.
I assume the clutch is stuck in the engaged position for some reason. I followed tech tips on this page, made sure the boss/ assembly was seated properly, clutch cable is adjusted properly, etc...
Any thoughts ?
Cheers and thanks !
Any thoughts ?
Cheers and thanks !
