I just bought a XS 1100 SG in the spring and still learning about the bike . Can anyone tell me if the gas tanks on a XS 750 and 850 are the same as the 1100? I have only seen a few pictures of a 750 tank but it looks like it is the same size and shape. Thanks.
gas tanks
gas tanks
BDF Special
Dyno tuned to 98 hp at the rear wheel.Tags: None
According to XS Part Number Finder, no
tinman905.
This site ( XS Part Number Finder ) is a good way to find what fits what.
You'll need to register, but it's well worth it.
Go to Parts Finding and then Donor Bike Parts up at the top of the page.
They even list 650's as donorsNubee
Thanks nubee!BDF Special
i had a 79 special xs750 for about 3 years and it was a smaller tank i beleive???" She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. "
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
mikes650 front fender
led's gallore...
renthal bars
gold valve emulators
vmax tensioner
Rifle fairing
I have owned both model of bike simultaneously, and I have attempted to swap the tanks, but they will not interchange. The mounts are different, and the xs11 has indentations in the bottom of the tank, to clear the valve cover, and the 750 tank doesn't. I believe the 750 tank is slightly bigger than the 11's.
That's too bad there a couple for sale on ebay cheap and in very good shape. Thanks for the tip.BDF Special
I have one special tank left in pile. No emblems, holes filled, no petcocks, has sending unit and gas cap with key. Black paint, some primer flat black near seat area at back of tank from a dent repair, inside not been coated, still good, not rusted out. if you need one. Use PM please andreas.
could you put a small spacer on the part were it bolts down by the seat and connect the front on top of the mounts somehow. there was a universal kit i think in a magazine a while back??? some guy got a patent on somekind of universal hookup." She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. "
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
led's gallore...
renthal bars
vmax tensioner
Rifle fairing
I you look at the pockets on the inner part of the tunnel where the rubber tank mounts sit, on the 750 tank, you'll see that they are in a different position than those on the xs11. You may be able to relocate the pockets, to adapt it to the 11, but I think the petcocks are located in such a place that they hit the airbox, or carbs.
