Battery
  • pastaman
    • 9
    • north east ohio
    Battery
    HI, I have a 81 XS1100SH. I have had a problem getiing it to run right. I have replaced just about everything and found out the other day I had a dead cell in my battery. Would this play a big part in it not running 100%? Thanks
  • mro
    • 4276
    • Hayward, California
    If when running if you have 12 + volts should run OK.
    Over 2,000/2,500 rpm should be over 13 volts.
    TCI requires 10 + volts to fire ignician.
    Bad battey can cause problems.
    How about a little detail on what you've done?
    and a little bit about condition and history of your special.
    mro
    btw, welcome to XSland
    got any pics of your bike to post
      Yes, Welcome!
      Like MRO said, TCI needs ~10.5 volts to work properly. With a dead cell, if you have 8=(1.5 volts missing), drops 12 to ~10.5 volts.....so this very well could be your problem. Relatively simple fix. Once you get a new battery IF it's still misbehaving, come on back and post a better history, symptoms, etc., and we'll have a go at it!
      • pastaman
        • 9
        • north east ohio
        Thanks for your response, My Xs is in great shape. I have replaced the coils (used), volt reg, carbs, rejetted. It has a 4 into 1 and individual air filters. Vacuum diaphram has been replaced also. My battery does have a dead cell and once it charges it drops off voltage rapidly. I have worked on this bike all summer and I am about to go nuts.Any help or suggestions would be great. Thanks for your help, Jim
          Hi Jim & welcome,
          replace the battery for sure. Until you have the whole 12Volts available you can't possibly discover whether there is anything else wrong with the bike or not.
          • pastaman
            • 9
            • north east ohio
            Thanks. I will stay in touch and let you know. Thanks again
