Just trying to quiet the fairing. I find it makes a lot of noise.
Besides reflecting the exhaust and engine noises back at me, I get a lot of buzzes, especially above 5000rpm.
It would give me a headache in fairly short order.
I was just wondering if any of our users has found ways to quiet any of the little noises from the fairing and lowers.
Also, the little hinge pins broke off on my Cycle Sound cover. It looks like they can be replaced with something. Anyone ever have to replace these?
). Spray insulating foam. I pulled all the crap outa the fairing I had stored. I used clear plastic tubing to run the wiring thru the front, inside portion of the fairing. I lined the inside with masking tape to facilitate future removal. I filled the front inside portion with foam and part of the side compartments, I only put about 2 inches worth here to maintain some storage space. There were drain holes there that I plugged up but that has not presented a problem yet. Once it cured, I was able to trim it back some to maintain apperances (how often does someone check the inside of your fairing
). It got rid of a substantial amount of the resonance the fairing creates. The fairing will always magnify engine noises just cause of how it directs noise back to you but the foam job helped alot. Make sure your run you wiring thru some type of conduit and make it big enough for future needs. I DID NOT fill the fairing completley, just the front portion and part of the bottoms. I tried removing some of the foam to see how the tape job worked and I could remove it completly if I needed to.
