Hi, I bought a 1982' XJ110j Maxim with 16,000 miles. Although gears were replaced, it needed the 1st gear fix. After joining this forum, reading all the important information about these Bikes, and with the help of TopCat by email I did the fix on all gears related. Following the advice of things to check out I found it needed a couple other things. I brought the clutch up to specs with new springs and clutch cable, brakes up to specs with new pads, and changed all fluids. I changed fuel tank to a new factory oem black one that came with the bike, painted the side covers to match, and put on new tank emblems. I am replacing the shiftlever return torsion spring when the part comes in.
It now runs great except for a not noticed before, slight clicking, ticking noise that seems to come from the rear end. It does not make it on the center stand. It goes away when leaning to the right in the first few gears while putting at around 1800 to 2200 rpm's. I took off the rear tire and greased the driveshaft splines, found nothing wrong. Any Ideas?
I would appreciate any knowledge regarding the noise. I read the posts and followed the threads but none were similiar.
