one muffler turn blue
  • brownbear1000
    • May 2007
    • 83
    • Bay View wisconsin
    why whoud one muffler turn blue on the right side <no. 3&4>
    but not the left side <no. 1&2> bike had ben back firing so I had to ride it home with the choke on full to keep it from back firing when I got home it ran ok 1979 xs 1100
  • Stralya
    • Apr 2006
    • 791
    • 'Blotto Grotto' Wodonga, Victoria, Australia.
    Same thing happened to me, it's a mystery alright.
    Automotive Imbecile.
    Proud owner of 'The Swiftcicle'. (Swifty for short)
    '78E Full Vetter Dresser.
    1196 Big Bore Kit.
    • AlanB
      • Oct 2006
      • 705
      • Scotland
      Hi Guys,
      You got a muffler full of unburnt fuel, then got a spark into it......... I am sure you can work out the rest for yourselves!
      AlanB
      If it ain't broke, modify it!
      • petejw
        • 2269
        • sydney australia
        stralya,
        out of curiosity the muffler that went blue
        on urs, was that the side that had a small
        hole in the header pipes?
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • brownbear1000
          • May 2007
          • 83
          blue muffler
          yes my muffler has a small rust hole under it
          • planedick
            • Mar 2005
            • 2068
            • Yorba Linda, California
            Your answer
            Hole in muffler reduces back pressure causing a lean condition and that's what turns your pipe blue....
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            Custom security system
            Stainless braid brake lines
            • Stralya
              • Apr 2006
              • 791
              Hi Pete.
              I'm not sure what side. I'll have a look tomorrow, it's pissing down at the moment but I'll bet it's the right side.
              I'm going to check out sandblasters tomorrow and see how much it will cost to do up my four into ones. If it's not too expensive, I'll get them done and paint them up with nice red manifold paint. I got a can of brake caliper paint here but I don't think it's heat proof enough.
              If I get them sandblasted and painted properly and they look good I might just leave them on.
              It will be all together on Friday. I want to go to Wilmot on Saturday or Friday night if I get it all done. I want to have a few beers with my brother so if it's OK, I'll swing by your joint on the way. I know you have your daughter but I just want a couple of pixs done and let you take it for a blat.
              I'll give you a ring Friday if I don't hear from you sooner.
              Cheers cobber,
              Dan.
              1196 Big Bore Kit.
              • brownbear1000
                • May 2007
                • 83
                paint pips
                I painted my headers on my truck with veary hi temp paint and it jest burened off in two weeks powder coating them may stay on and last longer
                • Stralya
                  • Apr 2006
                  • 791
                  Left side
                  Hey Pete,
                  Oddly enough that hole was on the left side.
                  1196 Big Bore Kit.
                  • HobbyMan
                    MeatHead Idiot "GURU"
                    • Jul 2006
                    • 1801
                    • Colleyville, TX
                    Check to make sure you have good fuel flow to the side that is turning blue, Definitaly sounds lean. Open the float drains and put petcocks on prime to get a "flow" check.
                    Acta Non Verba
                    • mro
                      • Oct 2005
                      • 4276
                      • Hayward, California
                      Low float level can do it to one side or one pipe, but should color header starting from head....
                      mro
                      • mro
                        • Oct 2005
                        • 4276
                        Burnt exhaust valve?
                        Valve out a spec or adjustment?
                        mro
                        Hmm...if I think about it a little longer maybe can come up with a few other but unlikely reasons.
                        • brownbear1000
                          • May 2007
                          • 83
                          bike runs good when I get home all started after I power washed it.
                          • TERJE ANDERSEN
                            • Aug 2003
                            • 106
                            • BERGEN,NORWAY
                            BLUE JOB !
                            Hi ! Use Blue Job on the blued areas and the blue colour will dissapear ! I have used it myself,and it worked even better then I had expected. Great product and it will also polish all your chrome nice. However ,DO NOT use on aluminium surfaces!
                            TERJE
                            `79SF
                            `80SG x 2
                            `80LG x 2
                            `81SH
                            `82XJ1100J
                            `83CB1000 CUSTOM
                            `79WIFE
