Went on a long ride over the weekend. Skyline drive in VA down to Roanoke for the mid east members. BIke starts to sputter and backfire real bad when it gets hot. I think it might be runnin rich, but when I got my carbs synced (before the ride) the plugs showed I was running lean. before the sync I had been runnin for about an hour on the freeway around 5k rpms. So the mech ( my buddy) backed out the mix screws 2 full turns. I checked my plugs before the long trip and they looked a liitle rich but have'nt yet after. During the ride I turned them in a 1/4 turn with no effect. Also when I start it in the morning I only need the choke for about 30-45 sec. Backgroud: 79 standard, pod filters with TC's velocity stacks, open header with washer inserts for back pressure, inline fuel filters, 145 main jets, 45 pilots.
Question: could two turns out on the mix screw take you from lean to rich( one end of the spectrum to the other)?
Any one got any suggestions?
As soon as I can find a pair of cheap mufflers I am gonna put them on and see what happens. But until then what do you think rich or lean when warmed up/ hot.
Thanks for your help
1 is good tan, 2 rich black, 3 rich black wet, 4 white and lean. So now that I realize that there is an obvious problem what would cause this? I know the sync is good cause I helped him do it with the MERC sticks. Maybe my floats arent ali set exactly at the same hieght? I know the needles are all set the same. I am pretty sure about the mix screw positions. I know my floats could be screwed because of a previous attempt I made to get them at 25 mm. When setting these is it 25mm from the gasket surface, or do you remove the gasket and go off the carb body?
