Runnin crappy when hot
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    Pickups
    Left side by the shifter
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • audijunky
      • Apr 2006
      • 707
      • VA
      real quick, left as sitting on it or left as in looking at the bike from the front?
      79 XS1100 modified standard
      straight pipe 4-2 exhaust
      Owned 83 Honda V65 Magna
      Owned 02 Vstar 650 classic
      owned 85 Honda Shadow VT 700C
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        sitting
        XJ1100K
        Avon rubber
        MikesXS black coils
        YICS Eliminator
        • audijunky
          • Apr 2006
          • 707
          • VA
          well what is under the right side cover? I thought that was the pick up coils, oh wait , that is probably alternator of sorts.
          Thanks
          • Axel
            • May 2007
            • 869
            • Renfrew,Ontario
            A generator maybe
            XJ1100K
            Avon rubber
            MikesXS black coils
            YICS Eliminator
            • audijunky
              • Apr 2006
              • 707
              • VA
              thats what I meant generator, can't believe I said alternator
              I had a brain fart
              Thanks Axel
              • Axel
                • May 2007
                • 869
                • Renfrew,Ontario
                what is it ?
                Maybe it is a alternator . Specs says A.C. generator and alternator in another report
                XJ1100K
                Avon rubber
                MikesXS black coils
                YICS Eliminator
                • AlanB
                  • Oct 2006
                  • 705
                  • Scotland
                  Hi guys,
                  Most manuals tell you in the intro that when they refer to "left or right" they will mean "as seen from the driving position". Most mechanics use the same description.
                  Devices which generate electricity are called generators. Electricity is commonly generated in one of two ways; As D.C. (direct current) by a dynamo, Or as A.C. (alternating current) by an alternator.
                  The XS11 has an alternating current generator; also known as an alternator....... both mean exactly the same thing......
                  AlanB
                  If it ain't broke, modify it!
                  • audijunky
                    • Apr 2006
                    • 707
                    • VA
                    Doublr brain fart, for some reason I was thinking distributor when I had the first brain fart
                      • 5062
                      It is beginning to smell funny in here...
                      • audijunky
                        • Apr 2006
                        • 707
                        • VA
                        No worries , thatrs just the smoke coming outta my ears, or my breath
