stops running after 30 min
  • timeless-cowboy
    • May 2007
    • 25
    • akron ohio
    hello all heres my latest question.....fisrt my bike stoped running after rideing for about 30min it sputterd and died no matter how much throttle i gave it( like some one turnd a switch off).
    so i thought maybe the ignition module was over heating and changed it
    ,,,,,, no change,so i changed the coils out,,,still no change
    so the real question is whats left that can effect the bike in such a manner?
    after the bike sits for 10 to 15 min it will restart and but not run real smooth unless its left for a long while an hour or so
    ok this one gose to the think tank.
    1980 xs1100
    1981 xs 400
    1982 verago 750
  • 81xsproject
    • 3185
    • Fortuna, CA
    literally! Try running with the gas cap open. If the breather valve in the cap sticks fuel will stop flowing to the carbs. Then after it sits for a while the vacuum in the tank finally returns to normal and it will run again.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • mro
      • 4276
      • Hayward, California
      Should have checked if it had spark when condition occured.
      (easy/quick to check)
      No spark?
      Would check coils and/or TCI
      Got spark?
      Check that carbs are getting fuel
      (gas cap vent plugged?)
      mro
      btw, good read in tech tips about coils
      • 79XS11F
        • 3563
        • Ottawa, Ont. Canada
        put in another quarter
        :-) sorry couldn't help myself
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
        • 79XS11F
          • 3563
          Also check that the engine is not OVERHEATING. If it is being starved of fuel it will run leaner and HOTTER as the fuel supply dried up until the engine dies. I bet it fires up after it cools off ... right.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • Jimbo11
            • 51
            • Norman Ok
            "chitty chitty bang bang we love you"
            78 Standard Pix's Xs1100
            ( Pop's Ride ) not running
            79 special New to the House
            (Okie) running
            • planedick
              • Mar 2005
              • 2068
              • Yorba Linda, California
              Check this
              Ballast resistors have been known to get hot and open. After cooling down they work again 'till they get hot again.....
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
              Custom security system
              Stainless braid brake lines
              • timeless-cowboy
                • May 2007
                • 25
                • akron ohio
                ballist resistor
                ok i give where is the ballist resistor located and ill see about swaping it out
                1980 xs1100
                1981 xs 400
                1982 verago 750
                  Left side, under gastank, just above valve cover, red/white wires going to it! Jumper the wires together that you remove from it on the frame side.
                  • timeless-cowboy
                    • May 2007
                    • 25
                    • akron ohio
                    ballist
                    cool would it kinda shiny and silver too?
                    1980 xs1100
                    1981 xs 400
                    1982 verago 750
                      I thought we had a photo, and we did, it was in the Dyna Coil replacement tip!! It's just below the rubber gas tank cushion, so yes, it's silvery shiny!
                      • Dragon Tamer
                        XStremely XSive(Deceased)
                        • Sep 2006
                        • 426
                        • Half way between Chili and Winter Wisconsin.
                        Well now, that ought to help.
                        The Old Tamer
                        _________________________
                        1979 XS1100SF (The Fire Dragon)
                        1982 650 Maxim (The Little Dragon)
                        another '82 650 Maxim (Parts Dragon)
                        1981 XS1100SH (The Black Dragon)
                        If there are more than three bolts holding it on there, it is most likely a very important part!
                        • timeless-cowboy
                          • May 2007
                          • 25
                          • akron ohio
                          feel the love
                          you know Dragon I just feal the love comming from your direction.
                          but i do thank you guys for helping me out on this and you know they say a photo is worth a thousand words
                          thanks TC and Dragon
                          1980 xs1100
                          1981 xs 400
                          1982 verago 750
                          • Pat Kelly
                            • 3046
                            • Golden Valley, AZ
                            Hey!!! That's my bike
                            Pat Kelly
                            <p-lkelly@sbcglobal.net>
                            1978 XS1100E (The Force)
                            1980 XS1100LG (The Dark Side)
                            1999 Suburban (The Ship)
                            1994 Dodge Spirit (Son #1)
                            1968 F100 (Valentine)
