A few weeks ago I had to free up a stuck clutch on my 80G...put it against the wall and banged it into first twice. Fixed everything. Clutch worked fine. Rode around the block...clutch wouldnt shift into anything but 1-N. Pulled the shift cover off and fixed this. Then I had the ever dreadfull no spark issue. Get that fixed...get the bike running decently. Cant even take off because rear wheel pulls when I put in gear with lever pulled. I had adjusted the clutch before I took it for the first ride. Didnt mess with it the whole time I looked for the spark problem and the shifting problem. Printed out the clutch adjustment procedures and took them to the shop, adjusted, no, readjusted, no, readjusted, no, etc. etc. etc. I cant ride because even if I rev high and slip the clutch to get going it stalls and skids. Any ideas? Clutch cable came off Ebay from a 79 but it woked fine before. What am I missing?
Please refrain from kicking me in the nads when I do dumb stuff. I simply didnt think about it logically. Saw "loosen" and naturally assumed lefty loosey. As you can tell there are certain parts of bikes Im not so well acquainted with.
