Clutch adjustment
  • roach25681
    • Jun 2007
    • 69
    • Calhoun GA
    Clutch adjustment
    A few weeks ago I had to free up a stuck clutch on my 80G...put it against the wall and banged it into first twice. Fixed everything. Clutch worked fine. Rode around the block...clutch wouldnt shift into anything but 1-N. Pulled the shift cover off and fixed this. Then I had the ever dreadfull no spark issue. Get that fixed...get the bike running decently. Cant even take off because rear wheel pulls when I put in gear with lever pulled. I had adjusted the clutch before I took it for the first ride. Didnt mess with it the whole time I looked for the spark problem and the shifting problem. Printed out the clutch adjustment procedures and took them to the shop, adjusted, no, readjusted, no, readjusted, no, etc. etc. etc. I cant ride because even if I rev high and slip the clutch to get going it stalls and skids. Any ideas? Clutch cable came off Ebay from a 79 but it woked fine before. What am I missing?
    80XS11G (heavily modified) "Snot Rokkit"
    Deuces Wild
    Custom Paint & Body
    1200 N. Wall Sreet
    Calhoun, GA 30701
    770-608-3779
    It sounds like you're not getting enough "pull" on the lever to disengage the plates. When you started the adjustment process, did you run the cable slack adjuster all the way "in" before you started working the acual adjustment screw inside the cover?
    • roach25681
      • Jun 2007
      • 69
      • Calhoun GA
      Errr....the instructions said to "loosen" it...so naturally I turned it left until it was all the way unscrewed. This correct or backwards?
      Deuces Wild
      Custom Paint & Body
      1200 N. Wall Sreet
      Calhoun, GA 30701
      770-608-3779
        I believe you want to turn the slack adjuster so it makes the cable looser, as opposed to tighter, which would mean screwing it fully into the mount.
        • roach25681
          • Jun 2007
          • 69
          • Calhoun GA
          Please refrain from kicking me in the nads when I do dumb stuff. I simply didnt think about it logically. Saw "loosen" and naturally assumed lefty loosey. As you can tell there are certain parts of bikes Im not so well acquainted with.
          Deuces Wild
          Custom Paint & Body
          1200 N. Wall Sreet
          Calhoun, GA 30701
          770-608-3779
            Hey, don't sweat it, roach. We've all had our moments, and most of us will probably have more.
