recomended filter?
  • 77crewcab
    • Aug 2006
    • 87
    recomended filter?
    What would be the recomended air and oil filter brand/part #. I am looking for a stock replacement air filter at this time.
    80 XS1100LG
    Hey Crew,
    Here's a list of brands and oil filter's that will work:
    autozone SP2
    Napa 4933
    STP: SMO-2
    Wix 24933
    Fram CH6002
    **Make sure it has BOTH rubber O-rings in the kit, one for the chamber, the small one for the filter bolt!**
    OEM Air filter, not sure if it's available from Yamaha still, you can get K&N style by Unifilter from JCW, and probably other sources.
    • 77crewcab
      • Aug 2006
      • 87
      What about something from Fram or Wix that will replace the stock filter. Thats all I meant just don't want a k/n or foam style.
      80 XS1100LG
      • Pat Kelly
        • 3046
        • Golden Valley, AZ
        (just my opinon here)....
        K&N for the air filter is the way to go. Recommended cleaning interval is 50-100,000 miles. Never needs to be replaced.
        Buy one and your set for the life of the bike, no further costs, no need to open the airbox.
        Pat Kelly
        <p-lkelly@sbcglobal.net>
        1978 XS1100E (The Force)
        1980 XS1100LG (The Dark Side)
        1999 Suburban (The Ship)
        1994 Dodge Spirit (Son #1)
        1968 F100 (Valentine)
          If you take your OEM one to Walmart or Autozone and match one up to some auto one, then please post here for everyone! It's a very unique shape and size, I got rid of mine years ago, so I didn't try to match one up!
          Pat, how can the actual K&N filter stay clean enough to work for 50-100K miles? The dust plus the oil vapors from the crank vent hose I would think cause them to get coated and clogged just like OEM?
          • 50gary
            • Apr 2006
            • 225
            • Saginaw, Michigan. USA Third stone from the sun
            K&N air filters do last the life of the bike but still need periodic cleaning. Do not use compressed air on K&N air filters. Wash with low pressure, (Garden hose) do not dry with heat. This is information from the "Two Guys Garage" cable TV car show. FWIW?
            Cheers, 50gary
            • excess11
              • Oct 2004
              • 256
              • Rockville Md.
              K&amp;N
              I use a leaf blower to dry the K&N filter,Works good!!! I also use the leaf blower to dry the bike after I wash it to keep from getting water spots. Yeah leaf blower!!!!!!
              Dan ( A.K.A.- MacGyver )
