Custom Exhaust
  • Filter
  • Custom Exhaust
    I have a 80 special and I want to change the exhaust on my bike. I like the look of a 4-1 but I hate that it goes under the bike. I want to build my own header that collects under the right side peg. I would have all of the primary tubes collect into a 2.5" collector. Then the 2.5" pipe would run alongthe side of the bike and dump out the side, I want something like the sidewinder exhaust on drag bikes. My question is that if i build this exhaust with a 2.5" pipe will it provide enough backpressure for the motor? And would it be loud(with no baffels)?
  • #2
    hi i would say 2.5" is way too big,most sports bikes run2" big pipes help max power but narrower pipes help torque.if you really want a big chunky pipe for looks,i would suggest a 1.5"pipe and a 2.5" cover,by that i mean weld another skin of larger pipe over the top helps the look and pipe wont be as loud/hot.also should give enough back pressure.as for baffles you can buy 6" custom baffles for customs/chops,if when its made its too loud try one of these shorten it 1/2" at a time to get the best balance between noise and smooth running. this is my opinion for what its worth...good luck with your project
    mick
    xs1.1s(x2)
    gsxr1100(1127)
    gsx1100g(x2)
    trophy900
    bonneville750
    http://www.tonyfoale.com/
    • #3
      I have a Kerker 4 to 1, and the collector is a 2" outside diameter. Just FYI!! RB
      • #4
        and your point is?
        mick
        xs1.1s(x2)
        gsxr1100(1127)
        gsx1100g(x2)
        trophy900
        bonneville750
        • #5
          Just trying to give a comparison of what a manufacturer has done with this bike and exhaust........No harm or egotistical ramblings intended......RB
          • #6
            i said i thought 2.5" was too big, and you said "ive got a 2" one"...i dont see the relevance,i already stated most sport bikes run a 2" pipe, ...i'm confused.
            mick
            xs1.1s(x2)
            gsxr1100(1127)
            gsx1100g(x2)
            trophy900
            bonneville750
