Coils??
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    TCI PINOUT
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • roach25681
      • Jun 2007
      • 69
      • Calhoun GA
      Hmm...according to that...the exposed wire I have is the ballast bypass input from solenoid. I assumed it did not matter since it ran fine without it before but....im open for anything at this moment.
      80XS11G (heavily modified) "Snot Rokkit"
      Deuces Wild
      Custom Paint & Body
      1200 N. Wall Sreet
      Calhoun, GA 30701
      770-608-3779
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        TCI
        Keep at it man . To bad you couldnt borrow a TCI or try yours in another bike . Its not often they die completely but...
        XJ1100K
        Avon rubber
        MikesXS black coils
        YICS Eliminator
        • roach25681
          • Jun 2007
          • 69
          • Calhoun GA
          #34
          Thanks for all the tips and suggestions. I guess I will just give it another shot tomorrow... Yes its a damn shame I cant borrow a TCI from anyone to see if thats my problem. Or some coils. Ive never seen another XS1100 in my area.
          Deuces Wild
          Custom Paint & Body
          1200 N. Wall Sreet
          Calhoun, GA 30701
          770-608-3779
          • Axel
            • May 2007
            • 869
            • Renfrew,Ontario
            #35
            Getting closer
            Well . If you passed Randy's test (movie) the problem is between the coils and the TCI(which is ok) . Rare for two colis to go at once so ... I'm betting on something common to them . Maybe a break in the red/white wire between the TCI and the coils . Check for voltage(key on) on this wire at the ign coil plugs .One is orange wire and red/white wire and the other coil plug is grey wire and red/white wire . I'm willing to bet something is wrong with this wire , Once again I dont have an XS so there may be other things that I havent ran into (ballast resistor).
            Good luck
            XJ1100K
            Avon rubber
            MikesXS black coils
            YICS Eliminator
            • roach25681
              • Jun 2007
              • 69
              • Calhoun GA
              #36
              The wires you speak of is where Ive taken my ohm resistance measurements.
              Deuces Wild
              Custom Paint & Body
              1200 N. Wall Sreet
              Calhoun, GA 30701
              770-608-3779
              • randy
                • Dec 2003
                • 4521
                #37
                roach,
                I think you hit it. The ballast bypass is needed. When cranking, this wire bypasses the ballast resistor, giving the coils full 12V. It does that because during cranking the starter draws a lot of current, enough to drop the battery voltage too low to work the TCI.
                Also you wrote that you moved the TCI around and got spark breifly. That tells me that you may have a bad connection at the main (large) TCI plug. One of your harness wires inside the connector body may be loose from it's connector or the wire is corroded.
                You can pull the connectors out of the plug, ONE AT A TIME, by inserting a small pick to relieve the locking clip. Look down into the business end of the plug and you'll see the locking clip. Before re-inserting the connector, re-bend the clip so the connector will lock again.
                • roach25681
                  • Jun 2007
                  • 69
                  • Calhoun GA
                  #38
                  (Strange Dr. Frankenstien voice) ITS ALIVE!!!! It was the plug connection where the pickup coil wires plug into the wires that in turn plug into the TCI. Pulled each wire out individually and sanded them with a Dremel. Plugged it back in and BAM. Shocked me good! Was a hell of a feeling to finally get it figured out! Thanks to everyone for the help. Glad I didnt have to buy anything. Thanks again fellas!
                  Deuces Wild
                  Custom Paint & Body
                  1200 N. Wall Sreet
                  Calhoun, GA 30701
                  770-608-3779
                  • GtrMn
                    • May 2003
                    • 248
                    • Springfield Va
                    #39
                    Cool deal!
                    XS 1100 LG
                    • roach25681
                      • Jun 2007
                      • 69
                      • Calhoun GA
                      #40
                      Yes, now I have come to realize that 27 year old wiring sucks, along with 27 year old carbs, which I already figured out.
                      Deuces Wild
                      Custom Paint & Body
                      1200 N. Wall Sreet
                      Calhoun, GA 30701
                      770-608-3779
                      • Dozzerbeast
                        • 4
                        • Kansas city, MO
                        #41
                        Hey Roach I beleive you said something about your old lady if someone helped you out with your problem? Looks like that would be Randy.
                        LOL
                        • roach25681
                          • Jun 2007
                          • 69
                          • Calhoun GA
                          #42
                          The thing I failed to mention is that I have no old lady
                          Deuces Wild
                          Custom Paint & Body
                          1200 N. Wall Sreet
                          Calhoun, GA 30701
                          770-608-3779
