This site will be temporarily offline this Friday April 18th from approximately 5pm PST (UTC-7), for a few hours or less (hopefully) for upgrades. See this post in Forum Announcements for more info.
The engine will swap just fine. But depending on what you want, you may need to swap the timing plate assembly from the 80 onto the 78 engine, or just keep the 78's since it's more tunable than the 80's! Also, you can use your 80 carbs, or IF you got carbs with the engine, you can use the 78's, again a bit more tunable. The 78 has hotter cams, and slightly more comp. ratio than the 80, so you should get more oomph from it!
79SF "The Teacher" . . .basket case! History shows again and again,
