Brake Piston Problem
  • grant1856
    • Jul 2007
    • 23
    • Sacramento
    I took the brake piston out and cleaned it. Now I can't get it back in the caliper. I did not replace anything or use a rebuild kit. How do I go about getting it back in?
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    Remove the seal and clean out the corrosion out from under the seal. Often you can put it back together with the old parts without it leaking...
    Geezer
    • grant1856
      • Jul 2007
      • 23
      • Sacramento
      Brakes
      It looks like I will need to replace the seal. I tore it up a bit trying to get it into there.
      • egsols
        • Jan 2006
        • 1090
        • Barrie, Ontario, Canada
        If you get the new seal with the kit make sure you use lots of the assembly lube. If you have an old seal and want to put it back in make sure you clean everything with just brake fluid and lube it all with brake fluid, it should slide right in. If you don't lube it and try to put in back in you'll probably scrath the crap out of it.
        Ernie
        • EZMoney
          • Oct 2006
          • 115
          • Castlegar, BC,
          Grant
          Partsnmore has the rebuild kits at a reasonable cost and master cylinder kits as well.
          I have had the caliper pistons apart on both my XS' and if you are very carefull they should go right back together.
          Make sure everything is spotless and smooth, use a generous amount of fresh brake fluid (but not enough that it squirts out all over and screws up the paint on the caliper ) and slide the piston right in. If it isn't going it is probably tipped a little, adjust and try again.
          Ed
          78/82 XS/XJ mostly made up of parts bikes
          XS1100 SG 1980 Will restore to original over time
          • Winterhawk
            • Jun 2004
            • 684
            • Missouri
            Be carefull with a K@L rebuild kit. Sometimes the square O-ring is to large and causes the piston to stick.
