Octopus Mess!!!!
  • bwilding_2000
    • 50
    • UTAH-SLC
    more help with fuel T's
    I have the 79 special.. I have got carbs with 4 fuel inlet hookups, 2 top 2 bottom. how do i hook them in? Do i need to T the lines that should be going in? 2 lines go to octy, 2 have a T split and one goes to the octy while the other goes to the carbs. So, How do I connect the other 2 inlets on the carbs?
      • 7947
      This is how it goes with the stock components. The lines marked #20 go to the fuel tees between the carburetors. What I did was plumb the left petcock to the right carburetors and the right petcock to the left carburetors. This gives me a lot more slack when I have to do maintenance.
        I think you are confusing the vent Ts on top for another set of fuel Ts.
        You have four Ts, two on bottom take fuel lines from the Ts, marked 20 in Marty's diagram. The two on top are air vents for the fuel bowls. They go to the air box nipples, at the top of the air box, above the nozzles to the carbs.
          • 7947
          Thanks. My bike is later, so I'm not really familiar with the vent tees. I got caught up in the hose routing.
          • bwilding_2000
            • 50
            • UTAH-SLC
            #35
            Thanks! That really helps me a lot!!! It has been a LONG time since I have had original carbs on the bike!!!!
            • Cobia
              • Jul 2007
              • 1587
              • Palm Beach County, Fl
              #36
              Five words...... Just get rid of it !!!
              1980G Standard, Restored
              Kerker 4 - 1
              850 Rear End Mod
              Automatic CCT
              1980GH Special, Restored
              '82 XJ1100 (Sold)
                • 3189
                #37
                -1 on that. Keep it as it is always a safeguard in case other parts fail.
                  • 7947
                  I'm with Rasputin on that. I find myself walking away from the bike with the petcocks on quite often. For me, the vacuum shutoff stays.
                  I have a '83 XS650. It has a side stand switch that kills the engine if I put it in gear with the side stand down. Have I ever driven off on the XS11 with the side stand down? ....yep.
                  Maybe I have these issues because I'm accustomed to the safety devices. I admit, the more there are, the more clutter in the systems. I think each individual needs to decide for himself which safety devices he can comfortably live without. I certainly don't believe the octy is universally bad.
                  • Poprock
                    • Apr 2005
                    • 594
                    • Oregon Coast
                    #39
                    My octy failed. Got a used replacement. It failed. Got a kit. Put in a new diaphragm. It failed. I'm running manual now. Occasionally I fail. I will put the octy back in when I find another diaphragm that doesn't leak. Bike runs same either way,
                      • 7947
                      I have posted this link before. I found it useful.
                      Rebuilding Yamaha Vacuum Operated Fuel Valves (Petcocks.)
                      • Poprock
                        • Apr 2005
                        • 594
                        • Oregon Coast
                        #41
                        Thanks for that tip! Now I know why my kit didn't work. I didn't clean anything, just put 'er back together. This is very helpful.
                        • XS11NEWROSS
                          • Dec 2013
                          • 48
                          • New Ross, Co. Wexford, Ireland
                          #42
                          My Version of In-Line filters with OCTY present XS1100SG Diagram
                          Hi guys, I am new to this as I have returned to my old habits only recently, having had a lot of trouble understanding the way to put in-line filters on the bike with the OCTY PRESENT, I thought I would try to re-draw the diagram you have already posted to help others too, hope it's ok!
                          You can view my diagram on the following link. Best wishes, Paul in Ireland.
                          Hosting Ireland - Holding Page - Your Domain Has Been Successfully Registered!
                          Paul
