Voltage Regulator?
  • DenzComp
    • Jul 2007
    • 109
    • Whitney Point, NY
    Okay...thanks.
    I guess I'll check the stator and jazz again.
    Andreas sent me two and I just threw one on that he said wasn't 100% sure if it worked.
    I'll go out and test crap later and let everyone know.
    Thanks for the info everyone.
    • DenzComp
      • Jul 2007
      • 109
      • Whitney Point, NY
      I'm getting a reading of 1.1 for the stator and the field coil is giving me 4.1
      I got these same number from two different sets.
      • DenzComp
        • Jul 2007
        • 109
        • Whitney Point, NY
        Also..I ended up having to buy a new battery....the battery in it was a month old and when I had the electrical problems it fried the battery. I haven't checked this one yet...but I hope it didn't fry this one too...
        Any ideas?
        • Geezer
          • May 2003
          • 2985
          • Willamina, Oregon 97229
          It's more likely your last battery was bad out of the box. Unless your bike was over charging and boiling the battery dry, the bike isn't at fault.
          Geezer
          • DenzComp
            • Jul 2007
            • 109
            • Whitney Point, NY
            I thought that could be the case...check your e-mail Geezer.
            • DenzComp
              • Jul 2007
              • 109
              • Whitney Point, NY
              After getting more info from Geezer I've narrowed it down to it being the Regulator...I've placed an order with Geezer based on he great prices and recommendations from everyone here. I cannot wait to get it.
              • DenzComp
                • Jul 2007
                • 109
                • Whitney Point, NY
                Okay. Got the part from Geezer today. I didn't expect it until monday or maybe tuesday.
                I put the tank back and fired her up..
                What should I being looking for voltage-wise, to make sure everything is working correctly, at the battery?
                  At idle, you could be getting ~12.5 volts, and it should go up to 14.5 or so at 2k rpm or slightly above. It shouldn't go over 15volts!
                  • DenzComp
                    • Jul 2007
                    • 109
                    • Whitney Point, NY
                    Man...I must have something else wrong then...I have the battery on trickle charge right now...maybe I ruined the battery again...
                    It's at about 11.9 sitting in the bike...I turn the key on and it drops down a bit..not sure exact numbers...then when I start it up it goes back up..but not over 12...I can rev it and watch the numbers climb a bit...but not over 13....
                    • DenzComp
                      • Jul 2007
                      • 109
                      • Whitney Point, NY
                      I think everything is actually working...just the battery may be weak.
                      Voltage drops when the key is turned on...then when I start it it just right up to where it was pretty much....when I rev it to about 2K its almost 12.
                      When I let of Rev it drops...but not below what it was to begin with.
                      I can watch the voltage climb or drop depending on the rev...so I'd assume it's working...just my battery needs to be charged more or I hurt it a bit.
                      Sounds like everything is working now though right?
                      • DenzComp
                        • Jul 2007
                        • 109
                        • Whitney Point, NY
                        Okay...it's up to 12 volts finally after being charged a bit. What should it be at just sitting, with nothing turned on?
                        When I start it up it drops to 11.47 and when I rev it to just under 2k its only 11.77.
                        So do you guys think I still have a charging problem or its the battery?
                        • DenzComp
                          • Jul 2007
                          • 109
                          • Whitney Point, NY
                          Answered my own question I guess.
                          Just went out and checked the voltage on my dad's bike.
                          12.97
                          I guess I'll let it trickle charge a bit longer. It's only been about 3-4 hours.
                            Just sitting with a full charge, a healthy battery will read something like 12.7 volts. While cranking, it should drop down to something like 9 volts (as long as you get it cranking fast, that is good enuf). With the headlight on at idle, you can watch the volts slowly drop until the battery is not capable of running the bike (like 10 volts). At least that is what it is like with a stock VR. Break-even charging (battery charge holding with voltage of battery) is at something like 1400 or 1500 rpms with a stock VR. This is why I like the ability to turn off the headlight is I am stuck in stop-n-go traffic. Of course, Geezer's VR may be a lot better.
                            12.97
                            • Geezer
                              • May 2003
                              • 2985
                              I just got in from Canada and I'm beat so I'll keep this short.
                              Check the voltage between the red wire from the reg/rec unit and ground.
                              It's a common misconception that you can check the charging across battery terminals. All this will tell you is how much power is in the battery.
                              Geezer
                              • DenzComp
                                • Jul 2007
                                • 109
                                • Whitney Point, NY
                                where can I test this without taking the gas tank back off?
