clutch switch replacement
  • jms
    • Aug 2007
    • 12
    • Pittsburgh
    My clutch switch is broken the wire is ripped off, I can only start in neutral which is a pain in the ass. I've searched and searched and I see plenty of threads about disabling it, but none about replacing it and I can't for the life of me figure out how to remove the damn thing (unless it's stuck which would explain why it won't come out) Has anyone replaced it? I would disable it but I'm afraid some idiot (could be a state inspection or other unforeseen event) will try to start it in gear and go for an unexpected ride.
    1982 XJ1100
    1982 XJ650 (needs help)
  • mro
    • Oct 2005
    • 4276
    • Hayward, California
    Pretty sure it's the same as the front brake switch.
    Small metal clamp on it. Been awhile but think you just use a small screw driver to pry clamp away a little and switch should come off.
    mro
      • 7737
      If you look at the underside of the lever, you will see a small square hole by the switch. That is the release mechanism for the switch. Just stick a small stiff wire, or little screw driver in the hole, and pull out the switch.You should be able to buy a new switch, as I think it's the same as most brake switches.
      • jms
        • Aug 2007
        • 12
        • Pittsburgh
        cool, I will look for that, is the wire and the switch one unit or is it meant to be two units?
        1982 XJ1100
          • 7737
          It should be one unit, with connectors that will hook up to something in the headlight bucket. Check the Yamaha parts fitch online, but I think it may be something that fits a LOT of other Yamaha models.
          • jms
            • Aug 2007
            • 12
            • Pittsburgh
            I have it on my 82 XJ650 (which I need to get running ) but I wasn't sure if it was a one piece. When I get home I'll test it and see if the switch actually works and if it does I may try a little solder surgery and get it working bikebandit reports the part for $16 and someone else is checking if they have one in the parts pile. At this point I've had the bike for about 48 hours and I have to say I do enjoy it.
            1982 XJ1100
