Need to purchase new spark plug covers (boots) that have the pretty white "NGK" lettering on them. I found the NGK site and need to know what ohm value I would need. Looking at some old posts looks like 10,000 but need verification along with wire size 7 MM I am guessing? Found some for as little as $3.00 a piece and need to know that they will work. thx
NGK Spark Plug Covers
DEW
One Red "Creation 1"
One Black"Creation 2"
One Black"Creation 3"
One ???? "Creation 4"
One ???? "Creation 5"
One ???? "Parts Bike"
All the above 1100 Specials
78 Standard (Ruf Ruf)
1980 Midnight Special
1978 650 SETags: None -
Hey Dew,
Did you happen to see THIS TECH TIP IN THE MAINTENANCE SECTION ?
Actually most of ours are 5Kohms, but folks have also gone with NO resistor....IF you're not worried about radio frequency interferrence=buzz..if you're not using a stereo/music machine while you ride. The TCI is not susceptible to RF. Yes, 7mm solid core wire is stock. Happy shopping!
T.C.T. C. Gresham
How nature points out the folly of men! -
Not sure if they're exactly right but I saw some on Mikes XS parts website. I think they were all of $2.50 each.79 Special Engine/80 Special Body - sold to bigray03Comment
Re: NGK Spark Plug Covers
Replaced mine some time ago and found that LB05F and YB05F were perfect. Both have the 5K resistors on those and fitted nicely.Originally posted by dewibp
LB05F has a 90 degree angle and goes to the 1&4, YB05F is a 120 degree and goes to 2 & 3. I also cut couple of mm from the of wire to improve the connection. This might have been the biggest improvement since carb. sync. for my bike.
EDIT: Just read the previous link...dang it was all there...---
Marko
'81 SHComment
