Frame reenforcement
  • #16
    Hi Guys,
    Like I said earlier, the brace which makes most difference is in the form of a "Z"; A pair of crossmembers with a diagonal between.
    Additional braces straight across, (Like PGGGs pic) don't make best use of the metal. top rails would be helped more by either fitting diagonals between the existing cross-braces, or fitting (Heavy!) sheet-metal corner braces, like the unmodded "Sport" frame I linked to earlier.
    Design and placing of braces for a frame is a bit of an art;and I am only an amateur!
    AlanB
    If it ain't broke, modify it!
    • #17
      Yep triangles are better
      • #18
        Yes triangles are best. I intend to do one behind the battery and will have to cut the plastic mud guard to fit around it. I also can fit one in the front without getting into cam chain access issues. I have also been told to pretty much just wrap the entire head with an added layer of sheet steel that crosses over on to the frame from the head. I will likely start the cutting of the tubbing this weekend.
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
