Pete
I didn't muck around with the plates in the diffusers. Initially I installed them with the original 12 plates they came with. But because the Jardine megaphones were deeper at the point the baffled seated...12 plates barely cleared the end of the meg. So I added 12 more for a total of 24 plates each side. There are about 13 or 14 plates protruding out of the megaphones now. The pipes have a very mellow sound if I ride normally.
However if I spur Zilla these pipes and baffles really wail.
As far as tinkering around with the number of plates for tuning purposes I really did not do that. I simply assumed this SuperTrickk setup would NOT flow as much as the stove pipe (4-1 with R1 can) and put as many plates as I could to insure it would flow.
Again I was wrong. It appears this dual megaphone rig does flow well. And apparently due to the design they help distribute the power over a wider range of revolutions. I'm starting to get a better feel for what is meant by "tuned exhaust". The engineers at companies like SuperTrapp, Jardine, and the likes obviously know what hey are doing.
Patrick
I see you did not take my advice. But since you are so "experience" with the utilization of dynamometers and you're such a great engine tuner......... where is YOUR dyno chart?
Of course if you posted one now everyone would know it is bogus...something you ginned up on a XLS spreadsheet.
There a HUGE difference between guys like you and guys like Me and Dan Hodges. You talk the talk. We walk the talk.
Patrick
