general question
  • WeaselWheelie
    • Jul 2007
    • 1
    general question
    Have an xs11, but have no idea of year or make. Seems to have typical 2nd gear problems, but no problem because it's in a dwarf car and fourth is running gear.
    Two questions:
    1) Are there flatslide carbs available or compatible with the xs11? If so, what make or motor is similar?
    2) What about throttle body injection?
    The motor has a stumble on the bottom end and clears out after getting up in the RPM band, but the stumble is really bad so obviously, it's not putting out the power it should. Would the intake boots have anything to do with this?
  • rman
    • 228
    • Stroudsbug PA
    VIN
    Start by getting your serial number from the steering column and comparing it to the XS/XJ 1100 Serial Numbers and Year/Model Table.
    edit *Umm, sorry, maybe still have vin on engine case?*
    Trying not to offend since Aug 28, 2010
    Disclaimer: I am an idiot. Pay no attention to the man behind the curtain.
    Owner of:
    1979 XS1100F (The Pig)
    140 mains
    45 pilot jets
    Floats at 24mm
    Running Rich
    "Arrogant, delusional tyrants can't be stopped by earnest words and furrowed brows. Action, strong bold action coming from a position of strength and determination, is the only effective deterrent." -Mitt Romney
      • 7818
      Do a search on replacement carbs, and you sholuld find some information. You can look at the engine number, and compare it to the frame number listings rman talked about. It will give you the year, as the engine and frame numbers matched on the XS11.
      The stumble is probably just a dirty pilot circuit, and easily fixed.
      Welcome to the site!
      • pggg
        • 1609
        • NZ
        VM33 smoothbores for racing, adjustable to fit old jap 4-cylinder bikes
