Need Help with '79 Air box assembly
  • grant1856
    • Jul 2007
    • 23
    • Sacramento
    What is the trick in installing the airbox to the carbs? It does not appear to have the room. I did not take it out myself.
    Thanks
  • Stralya
    • Apr 2006
    • 791
    • 'Blotto Grotto' Wodonga, Victoria, Australia.
    You have to install the airbox before you install the carbs.
    Automotive Imbecile.
    Proud owner of 'The Swiftcicle'. (Swifty for short)
    '78E Full Vetter Dresser.
    1196 Big Bore Kit.
    • mro
      • 4276
      • Hayward, California
      Bummer, guess I've been it doing wrong the last couple dozen times.
      Seems to be enough room if the bottom half is off.
      mro
      btw, the "tubes" in the filter box can get turned and will not want to go on easy. Turn em what ever way you need to get em all aligned first, then should go on carbs with out too much effort or force.
      mro
      • Stralya
        • Apr 2006
        • 791
        Hey mro,
        Is your air intake vent tube thingy still attached? I have two air boxes, one has a sawn off vent tube and that goes in easily with the carbs on, the other one has the intake vent still attached and there's no way it will go on, bottom part removed or not, with the carbs in place.
        Dan.
        1196 Big Bore Kit.
        • grant1856
          • Jul 2007
          • 23
          • Sacramento
          Vent tubing
          Yes the vent tube is still in place on the air box. It does not look like it comes off. Any suggestions?
          • grant1856
            • Jul 2007
            • 23
            • Sacramento
            Carbs in place
            When it was removed the carbs were attached and have never been removed so how should I go about replacing it without taking the carbs off?
            • Stralya
              • Apr 2006
              • 791
              It's much easier to pop off the carbs than to lose skin wrestling the air box in with the carbs on. Removing the airbox with the carbs on takes a lot of force and bending of the intake boots.
              These are expensive to replace so I'd suggest removing the carbs before taking the airbox off or re installing it.
              Dan.
              1196 Big Bore Kit.
              • grant1856
                • Jul 2007
                • 23
                • Sacramento
                Thanks Dan. Is there any trick to installing it after removing the carbs? Can I install the airbox assembeled or do I need to break it down? Here is a link to my airbox:
                Air Box
                • Stralya
                  • Apr 2006
                  • 791
                  Just remove the bottom part of the airbox, the part with the filter in it and you will have plenty of room.
                  Dan.
                  1196 Big Bore Kit.
