clear lense XJ(conversion)
  • dodjh
    • Nov 2006
    • 124
    • Buck Snort, Mississippi
    I could not find the conversion lense on MikesXS or Bikebandit----any other places you know of I might check? Checked J.C. Whitney and found the 80/100 watt bulbs.
    Thanks
    dodjh
    Semper Fidelis to my brothers serving on foreign hostile soil
    Let me make this perfectly CLEAR!
    Hey Dod,
    You might have missed it because it wasn't Xsactly labelled as Clear Lens, but crystal lens, but you can see that it's pretty much clear vs. the fresnel sculpted syle of the OEMs. Found in the Electrical/headlight section near bottom of page!
    7" Halogen Lamp Kit
    7" Halogen Lamp Kit - Diamond cut style Lamp unit with 12V 60/55 Bulb
    (P43T base) and bulb dust boot. Replaces stock sealed beam.
    Fits into stock retainer of 74-84 XS/TX 650 headlamp.
    XS1/XS1B/XS2/TX650(70-73) models must use #10-1156 "W" clip set and
    clip the lamp unit to the headlamp rim.
    Note: This unit is deeper than stock so there is less room for wirining inside lamp
    assembly.
    Part #09-0650 $35.00 USD EA.
    • dodjh
      • Nov 2006
      • 124
      conversion lense
      Hey T.C.
      Thats what happened ---Thanks for the part number
      and description.
      Will (Note: This unit is deeper than stock so there is less room for wirining inside lamp
      assembly)
      create much of a nuisance? Since the conversion is pulling
      less amps, can you put one 55W light on front (fog?)
      dodjh
        Hey Dod,
        I'm not sure where you are getting that it is pulling less amps?? IF you use the JCW 80/100 watt bulb, then you will be pulling almost twice as many amps as with the stock 55/60 bulb. I've got the clear lens on mine, and with the 55/60 bulb it's okay, but not great, that's why I added my twin 55 halogens, but I also have done a complete LED conversion for turns/tail/brake lights which has freed up considerable wattage/amperage but I still only run them when I'm running the highway, not much in town except when approaching an intersection and not sure about cars seeing me....I'm flash them on!
        • dodjh
          • Nov 2006
          • 124
          clear lense conversion
          Hey T.C.
          I think on the Mikesxs page or another link I read, that particular
          generation of lighting gave more visibility with less draw on
          the electrical system. I see what your saying ---go faster need
          more fuel. Thanks for the feed back and right direction to go.
          dodjh
