Crank Movement
    Crank Movement
    Is there supposed to be any play in the crank? I can grab the rotor of this spare motor and pull back and forth and get slight movement. Is there an acceptable amount or should this be solid?
    Thanks.
    Hey Tod,
    I did a quick search for Crank End Play, found these two, one is your old one before your transplant!
    A search for Crankshaft End resulted in many more posts, but didn't take the time to read them. Seems like a little end play is normal, but nobody had the specs?
      Thanks TC. Yeah, I remember asking the question before, but nobody seemed to have a precise answer at the time. The last time I noticed this, the crank had some up and down movement as well as some end play. This one seems tight except for a little bit of a clunk sideways in and out. I thought maybe another set of eyes may have the answer this time.
      • oseaghdha
        • 1075
        • N43.02.5,W88.14.2
        There should be side play
        Don't know the spec, but I would expect somewhere around .004" to .007". (HOT)
        XS1100SF
        XS1100F
