Adjusting Timing Chain???
  • MIDWAYAUTO
    • Jul 2007
    • 11
    I was reading on this site about adjusting the timing chain and I understand where the tensioner is, I would just like to clarify where exactly the "engine case cover over the timing plates" is? Or if someone had a pic that would be great. Thanks
    • 5061
    It is the roundish cover, left side, that says Yamaha on it. It has four allen bolts in it for removal. You can reuse the gasket a million times.
    • MIDWAYAUTO
      • Jul 2007
      • 11
      Will there be any fluid leakage? Thanks
      • JWSanders
        • 879
        • White House, TN
        If there is, than you have much bigger problems than timing.
        Nah, it's dry in there.
        80 XS1100SG
        81 XS400SH
        Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
        A Few Animations I've Made
          If there is oil in there, it COULD mean your crank seal is leaking. You also have a galley plug in that area that leaks sometimes, but no.. it's vented at the bottom and won't hold oil.
          • Crazcnuk
            • 2980
            • Hinton, AB, Canada
            What they mean is no.
            (then if you come back later to ask why yours had oil in there, then read the above answers)
            '05 ST1300
            • Axel
              • May 2007
              • 869
              • Renfrew,Ontario
              Cam Chain Tensioner
              Remove cover . Turn crank clockwise til 'C' is at the mark at 12 o'clock
              Loosen locknut on tensioner bolt . Loosen tensioner bolt. Tensioner will reposition itself automatically . Tighten bolt(not too tight) . Tighen locknut (not too tight) . Replace leftside cover. Ride
              Did I leave anything out ?
              Axel
              XJ1100K
              Avon rubber
              MikesXS black coils
              Iridium plugs w/ 1k caps
              MikesXS front master
              Loud Horns (Stebel/Fiamm)
              Progressive fork springs
              CIBIE headlight reflector
              YICS Eliminator
              • prometheus578
                XS-XJ Super Guru (RESIGNED)
                • Aug 2004
                • 4012
                • Olympia , Wa.
                Nope.
