suzuki carbs
  • petejw
    • 2269
    • sydney australia
    suzuki carbs
    for those that have done the carbie
    swap with the suzuki carbs, i might have
    come across a set of carbs i believe there
    36mm, but are off a 87 suzuki 750, i was
    also told that they do not have the accelerator
    pump, are these the right carbs, is there
    anything such as model numbers or anything
    i can go by. im hoping to have pics of the carbs by this aftrnoon,
    any info on these would b appreciated.
    btw ive tried to do a search with out success
    thanx in advance.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
  • petejw
    • 2269
    • sydney australia
    pics ofcarbs
    here are the pics ofthe carbs
    any comments appreciated.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • 81xsproject
      • 3185
      • Fortuna, CA
      you might want to pm AlanB or go find him on the UK site. I believe he did this swap.
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • 81xsproject
        • 3185
        • Fortuna, CA
        HERE is on of the threads I was thinking of.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
        • AlanB
          • Oct 2006
          • 705
          • Scotland
          Hi Petejw,
          Got your PM, and just seen your photos; those look like the 40s I have on my Trike - they have a brass tube on one side, and a rubber link on the other.
          If they are the same as those, they are basically too big for the XS.
          The carbs do not fit in the boots without stretching, the tops do not clear the tank (they are close to the frame!) And the XS doesn't flow enough to need such big carbs.
          If you want to take some sizes, I will check them against mine.
          AlanB
          If it ain't broke, modify it!
          • petejw
            • 2269
            • sydney australia
            Thanx for the info guys,
            ive sent off another email 2
            confirm the size, originally i stated
            i wanted the 36mm so ill just wait and see,
            thanx again.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • pggg
              • 1609
              • NZ
              pete, your carbs look real similar to these gsxr 38mm's, different fuel bowls, yours look like they can rig accelerator pumps, not needed if jetted right though, spacing on these ones 85-90-85, XS11 is 78-84-78, so won't fit the XS manifolds, but custom made manifolds you'd be laughing. The XS motor's hangin' out for free flow exhaust and big carbs, becomes a wild uncontrollable monster straining to get let off the leash...
              • AlanB
                • Oct 2006
                • 705
                • Scotland
                Hi Pete,
                To figure out if you can use 'em, just measure the carb where it fits into the boot at the head; the ones you want are the same outside diameter as the XS carbs, and the spacing between them should be pretty close to being the same as the XS.
                If you can get them onto the head, the rest will follow.
                This conversion is well worth the trouble; takes 15 years off the XS!
                AlanB
                • petejw
                  • 2269
                  • sydney australia
                  just had the size rechecked
                  and the guy states that there
                  36mm carbs.
                  there going 4 $150 Aud
                  so i mite give them ago,
                  will let u know.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                  • pggg
                    • 1609
                    • NZ
                    I'm guessing they're 74-88-74, could be tricky to fit em', pete, find out their exact spacing first
