Question for GEEZER!!!!
  • renegade_xs11g
    • 462
    • Mid-Michigan
    Having a problem with charging I think it's the rectifier,
    The Question is would a rectifier of a '78 XS750 (in labels it a "2D") work properly on a '80 XS11G (spec).
    TopCat said you may know....
    ALSO req'd you for a replacement????
    How many BEERS would you charge???
    My Photo Bucket
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    Some of the early 750 triples had the field coil grounded on one end and the other lead goes to the reg/reg. With this system the regulator powers the field.
    On the later 750, all 850 triples and all XS11 and XJ1100, the field coil gets power directly off the main hot lead and the regulator grounds the other lead to regulate the power.
    The short answer is if the 750 reg/rec is a later one, it's the same as used on the 1100. I don't know when the cut off date was on this change but the parts looked alike.
    Geezer
    • Lamric
      XStremely XSive(Deceased)
      • 410
      • Kenley, Surrey, England
      The 'Rectifier & Regulator Assembly' from an XS750-2D is the same part as on your XS1100 G, it's part number 1T4-81960-92-00 and it's used on.....
      XS750-2D
      XS750E
      XS750E-227501
      XS750F
      XS750SE-31121
      XS850LG
      XS850SG
      XS850H
      XS850LH
      XS850SH
      XS1100SF
      XS1100G
      XS1100H
      XS1100SH
      Brian
      XS1100 LG "Mr T", SG "ICBM" & FJ1200
      Check out the XS Part Number Finder
      Be not stingy in what costs nothing as courtesy, counsel and countenance.
      • Geezer
        • May 2003
        • 2985
        Anybody interested in a good deal on one of my reg/reg units?
        I have 4 units that I mis drilled some holes in the plate and I didn't catch it until final assembly. By this time the rectifier was already epoxied in and I the only choices were to fix'em or toss'em so I fixed them.
        Other than 2 extra countersunk holes in the backing plate, they're fine. I'm selling them as blems for $34.50 off the regular price ($60 plus shipping.)
        Send me an eMail at sales@OregonMotorcycleParts.com if you're interested in one.
        My new bride and I are planning to swing by Camp XS at Denny's in WA on the way back from Canada and I could deliver them there. We will also be in Port Angles, WA on the 15th and 26 of August.
        BTW, anybody know if there's a waiting period after buying a marriage license in Canada?
        Geezer
        • mro
          • 4276
          • Hayward, California
          "I am."
          is reportedly the shortest sentence in the English language.
          Could it be that "I Do" ....is the longest sentence?
          mro
            • 5069
            Like...a...prison term?
            mro
            • Geezer
              • May 2003
              • 2985
              If it's a sentence, it's one I'm happy to have. Sue is the only woman I've ever known that likes mechanical stuff.
              We'd take the trip up to Camp XS on the 70 standard but she finds it uncomfortable on long trips. I hate to say it but I think there is a wing in our future.
              Geezer
              • renegade_xs11g
                • 462
                • Mid-Michigan
                Thanks for the help.....
                Since it would seem that the reg/rect will fit, it raises another question...........
                I installed the rect from the 750 on the 11,
                still nothing, what else could be wrong????
                Thanks John
                My Photo Bucket
                • Geezer
                  • May 2003
                  • 2985
                  The next step is to check the resistance on the stator and field coils per the instructions in the manual.
                  Geezer
                  • renegade_xs11g
                    • 462
                    • Mid-Michigan
                    Did that......
                    Posted about it....then I changed rect, still same reading
                    I've stolen a bad rectifier?????
                    DUMB LUCK!!!!
                    My Photo Bucket
                    • renegade_xs11g
                      • 462
                      • Mid-Michigan
                      I am an IDIOT
                      had time to poke around a little more......
                      the stator (big coil) wasn't bolted to the cover, (MY fault)
                      have a little wear on the inside of the coil, and a little scratching on the one that is bolted to the crank
                      the question is: would that short out, both rectifiers
                      Thanks John
                      My Photo Bucket
                      • snowdog51
                        • 348
                        • st. paul ,mn
                        rect
                        the most liklly problem is the conn. by the
                        fuse block just because it looks good doesn't mean it is . unplug it and look.
                        as ever bill
                        bill hane
                        • Geezer
                          • May 2003
                          • 2985
                          Re: I am an IDIOT
                          Thanks John
                          No but it sure wouldn't help the stator. Double check that the stator isn't shorted to ground.
                          Geezer
                          • renegade_xs11g
                            • 462
                            • Mid-Michigan
                            THANKS FOR THE HELP....GEEZER!
                            the stator coil had continuity to the engine,
                            swiped the one from the 750, took the field coil too, still using the 750's rectifier
                            headlight came on as soon as the engine started,
                            the white wires felt a little warm @ rect
                            not hot, just a little warmer than the other ones
                            VOM reg over 12.5 volts @ 2500 rpm,
                            is that enuf'
                            Again, THANK YOU
                            John
                            My Photo Bucket
                            • snowdog51
                              • 348
                              • st. paul ,mn
                              charge
                              no when right its around 14 v
                              as ever bill
                              bill hane
