Kansas City Members/Help
  • vincer
    Deceased
    • Jul 2007
    • 109
    • Kansas City, MO
    I just got my XJ1100 and want to make it as road ready as I can. Right now I am riding about 15 miles one way to work and will start taking longer ventures as time permits. I have bought a repair manual and done some of the basics, carb boots, fork seals, but would like to have someone with some knowledge to maybe take a look at it, listen to it and give me some input. I am definitely interested in learning. Most shops are outrageous and I do not mind doing any of the work, but I hate to just start throwing parts at it. There are no issues that are begging to be corrected but I am sure there are things that need to be done. Any input would be greatly appreciated. Thanks for any help.
    '82 XJ1100
    '07 Harley Nightster (SWMBO'S)
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    XJ's in Kansas
    Welcome . Was it black with a torn seat and handgrip ?
    Check this link
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • Axel
      • May 2007
      • 869
      • Renfrew,Ontario
      not Kansas
      Sorry wrong number
      XJ1100K
      Avon rubber
      MikesXS black coils
      YICS Eliminator
        If the tires are new (Within 3-4 years old... no matter WHAT the tread looks like) and it seems to be running well, get some Seafoam from Walmart and run about half a can each through two tanks to clean the carbs up. Besides that, since you have a manual, carefully follow the directions and adjust the cam chain. Might drain and change the middle drive and final drive oil, but make sure you can loosen the top allen screw cap BEFORE you drain the oil.
        There's a link on the left side to things you should be looking for in general as far as maintanance and such. But as the saying goes... if it ain't broke don't fix it!
        I know of one other person in your area with an XJ, but I don't know how much of the work he does on it himself. He isn't on here much though. Maybe he'll chime in at some point? I did drive up there once to buy an XJ engine... better beer on your side of KC! : )
        We are having a rally in Eastern Oklahoma in the first weekend of October. Look in the Rallies/NA section to the left. We'd love to have another if you can make it. Great guys and even better to see a bunch of these bikes together.
        One other thing.... PICTURES!!! lol.
        • vincer
          Deceased
          • Jul 2007
          • 109
          • Kansas City, MO
          I have been slowly using the book to do some maintenance. I have adjustded the cam chain and clutch (last night) changed the middle and final drive gear oil. But I have not cleaned the carbs yet. I am kicking myself for not doing it when I changed the intake boots. I think I have an oil leak beneath the cylinder head and think this fall I will have to get the gasket replaced. I want to adjust the valves and am reading on that right now.
          I have been reading about the rally in OK and would love to go. I was also hoping to meet some people around here that I could hook up and ride with. This is my first bike in about 16 years.
          That is part of the original reason for the post. But I will not take the XJ on a ride if I am not satisfied that I have done everything that I can do to be safe! If I can get the wife to sign a permission slip then I would probably trailer the bike there and ride on Saturday.
          Pictures will come soon.
          '82 XJ1100
          • Brian_D
            • 355
            • Gardner, KS
            would like to meet up sometime but my work schedule for the next few months is not very flexible.....and I don't know much about the XJ specifics.
            may want to check out the Kansas City Area Repair thread posted by Winterhawk. I've never met him or used his services but he has helped a few people here.
            • vincer
              Deceased
              • Jul 2007
              • 109
              • Kansas City, MO
              Give me a shout when your schedule frees up.
              '82 XJ1100
              • jeffe
                • Oct 2004
                • 393
                • Westerville,Ohio
                Make sure you have no!!! rust in the gas tank. Will cause major headacjes down the road.
                78E ... Gone but not forgotten
                2006 Kawasaki Concours....just getting to know it
                  Seriously... if it seems to be running OK... don't pull the carbs off trying to fix it. Run a can of the Seafoam through it. I never tried it until recently.. thinking Berryman's would be just as good. The Seafoam is higher, but you do get what you pay for in this case.
                  If all else fails, the carbs are easier to work on than they are to take in and out on the XJ. Seems a daunting task at first.. but really pretty straight forward inside.
                  If you think you have a leak UNDER the head, I'd be willing to bet money that the valve cover is what's leaking. It can do some strange things. Mine was leaking once into the area around the #2 spark plug, leaking back though the air passageway, down my #2 carb holder, and right onto the fin that seperates the head and cylinders and running around the front... thought for sure a head gasket. Re-torque the head bolts to be sure, but go back over the valve cover ones also.
                  • yadada
                    • 150
                    • Louisburg, KS
                    My ears were burnin! Some one musta been talkin about me. I have a XJ and I'm in the vicinity of KC. Louisburg KS actually. You gotta watch those guys from OK.
                    Mine makes all kinds of darn noises, but keeps rollin. I'm not an expert on the bike by any means. It sounds like I've done to my bike about what you have to your bike, so we're in the same boat as to figuring out what's wrong with them.
                    I think on Sunday the wife and I are going to ride up to the Great Mall in Olathe and let her watch the MSF class, just so she gets an idea of what she gets to do when she takes the course. Not sure if we'll be on the XJ or the HD. I rode the HD for the first time in a while yesterday, dang that thing is slow.
                    I think we were going to go cruising around after that. Not all day or anything. We'll have to bale hay later on in the day so we'll probably be home at least by noon. You're welcome to tag along if you want. We'll be there early, 7:30 or 8 in the morning. If you want to ride along for a while let me know and we'll try to fix the time a little better. If you think you might show I'll try to ride the XJ. I have some wiring issues that are beggining to annoy me that I want to start fixing.
                    I'm planning on going to OK next fall....
                    Randy
                    "I didn't break it! IT FAILED!"
                    '82 XJ1100 "yamama"
                    '09 Buell Ulysses
                    '01 HD softail std - crunched
                    • vincer
                      Deceased
                      • Jul 2007
                      • 109
                      • Kansas City, MO
                      I will be out of town this weekend and next. But definitely want to get some riding done.
                      If you go to Oklahoma are you riding or trailering the bike(s)?
                      '82 XJ1100
                      • yadada
                        • 150
                        • Louisburg, KS
                        Should ride it, unless the wifey has a bike by then, and wants to go, and wants to ride her own bike, but doesn't want to ride that far.
                        So I plan on riding unless directed otherwise...
                        It's not a bad ride down to there actually, one very good road near Taleqah for sure.
                        Randy
                        '82 XJ1100 "yamama"
                        '09 Buell Ulysses
                        • yadada
                          • 150
                          • Louisburg, KS
                          not sure on the spelling of Taleqah...
                          Randy
                          '82 XJ1100 "yamama"
                          '09 Buell Ulysses
                          • vincer
                            Deceased
                            • Jul 2007
                            • 109
                            • Kansas City, MO
                            close enough. I understood what you meant. Sometime I type in cursive too. LOL
                            '82 XJ1100
                            • Winterhawk
                              • Jun 2004
                              • 684
                              • Missouri
                              Just PM me if you need any help. I'm no guru but more than glad to help. Since you're a member here the cost is next to nothing if not free.
                              I've been doing a few Harley's lately as they are the ones that seem to break more than Yamaha's do...LOL
                              I have the computer hookup for Harley efi's codes. I like my '02 Ultra but the XS1100's are still my favorite next to my Seca Turbo.
                              Bob Jones got mad at me when I bought a Harley
