Hi everybody, I am new to this forum and I have a xs eleven 1100cc ,19981.I buy it used.I have a fairing and a windshield installed in.I don' t know if it was there new or if installed after.Anyway I would like to remove it.But the spot light and flasher light is in.This is my question:Is there a way to install the lights without the fairing?I don' t need the windshield.
spot light whitout fairing
Tags: None
Probably you have 1101cc
So is your 81 an "H" (standard) or a "SH" (special)
On the standard turns mount to forks with a two bolt bracket.
On the special on the head light brackets.
Head light brackets should still be there under the fairing.
mro
btw, newbie's need to post a pic of there bike
Hey MRO,
His location is near Quebec, Canada, hence the French Accent!
Sebast, many sources for parts you need, Ebay, MikesXS.com. The fork mounting brackets for the Standard are no longer available from Yamaha, but still options. As stated, you can still mount them thru the holes that mount the "Headlight" bucket to the fork ears/brackets, or you can fashion/fabricate some out of simple angle bracket material!?
T.C.T. C. Gresham
