Fuse Box Replacement
  • oseaghdha
    • Aug 2006
    • 1075
    • N43.02.5,W88.14.2
    Anyone ever see this?
    Note the scabbed on inline holder for the headlights and the stripped twist tie holding the ignition fuse. YUCKY.
    Step 1: Get it out of there. Two screws and swing it up and out of the way.
    2. Install TC's fuse box.
    I used a hacksaw to slot the right side. I also notched the top corners to clear the large screws and to get it centered as much as possible top to bottom.
    I center punched for the other hole, and drilled it.
    Flat washers add strength and hide my sloppy work.
    Cut the wires out of the old box and label them.
    I stripped back the tape and separated the top wires from the bottom ones.
    Retape the bottom wires and run them through the metal loop.
    I attached the wires using the right angle connectors recommended by Hobbyman.
    I soldered them, crimped and applied shrink tube.
    This thing is the $hit! Runs on butane.
    It heats in about 15 seconds and includes a torch tip.
    There was a thread about traveling tools including a soldering iron. This is perfect.
    From the Shack.
    You can see the connectors also from RS.
    All done.
    XS1100SF
    XS1100F
  • mro
    • Oct 2005
    • 4276
    • Hayward, California
    Nice job, looks good
    I've had one of TC's fuse boxes for a while but have not had any problems with my OEM's so have yet to install it.
    mro
      • 1914
      Looks great
      how much did all the parts cost you and how long did it take you to do the conversion?
      • oseaghdha
        • Aug 2006
        • 1075
        • N43.02.5,W88.14.2
        Re: Looks great
        I got the fuse box from TC for I think $7. The connectors and soldering iron were about $29. Just the connectors were probably $3, I dunno, I wanted a new toy.
        I could have finished it up in maybe three hours, but I wasn't in a hurry because the bike is down for parts right now.
        XS1100SF
        XS1100F
