Fuse Box Replacement
  • oseaghdha
    • 1075
    • N43.02.5,W88.14.2
    Anyone ever see this?
    Note the scabbed on inline holder for the headlights and the stripped twist tie holding the ignition fuse. YUCKY.
    Step 1: Get it out of there. Two screws and swing it up and out of the way.
    2. Install TC's fuse box.
    I used a hacksaw to slot the right side. I also notched the top corners to clear the large screws and to get it centered as much as possible top to bottom.
    I center punched for the other hole, and drilled it.
    Flat washers add strength and hide my sloppy work.
    Cut the wires out of the old box and label them.
    I stripped back the tape and separated the top wires from the bottom ones.
    Retape the bottom wires and run them through the metal loop.
    I attached the wires using the right angle connectors recommended by Hobbyman.
    I soldered them, crimped and applied shrink tube.
    This thing is the $hit! Runs on butane.
    It heats in about 15 seconds and includes a torch tip.
    There was a thread about traveling tools including a soldering iron. This is perfect.
    From the Shack.
    You can see the connectors also from RS.
    All done.
    XS1100SF
    XS1100F
  • mro
    • 4276
    • Hayward, California
    Nice job, looks good
    I've had one of TC's fuse boxes for a while but have not had any problems with my OEM's so have yet to install it.
    mro
      Looks great
      how much did all the parts cost you and how long did it take you to do the conversion?
      • oseaghdha
        • 1075
        • N43.02.5,W88.14.2
        Re: Looks great
        I got the fuse box from TC for I think $7. The connectors and soldering iron were about $29. Just the connectors were probably $3, I dunno, I wanted a new toy.
        I could have finished it up in maybe three hours, but I wasn't in a hurry because the bike is down for parts right now.
        XS1100SF
        XS1100F
