let go of the start button, engine stalls, what did I forget
starts and runs but...
My Photo BucketTags: None -
That is true! Renegade, you can temporarily bypass the resistor by merely pulling the plug and jumping the harness side wires together, and try starting it! IF it starts and stays running, then the ballast resistor is bad, or bad connections. You can test the resistor with an Ohmeter, should be around 1.5ohms IIRC! Recent thread on making a replacement one from Radio Shack parts or automotive leftovers!
T.C.T. C. Gresham
This might be my fault
there is (or WAS) a part I took off thinking it was the 'tip-over' switch
red and red/yellow wire going to it,
about 1/2" x 1/2" x 2" or maybe 2-1/2"
I'd wager good money, I got the WRONG one!
even worse since the bracket came off with the thing
For list of things going on with this thing pics included,
SEE "DID SOME REPAIRS....DONE TO 4 I THINK" POST1980 XS11 Special aka The Monster
My Photo BucketComment
just for grins....
is that the "ballast resistor"1980 XS11 Special aka The Monster
Yep
That's it. That's the ballast resistor.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
You beat me to it
installed, turn key, push button, let go of button, stayed running
Thanks1980 XS11 Special aka The Monster
Tipover switch
You would be well advised to not remove the tipover switch. It will save your engine. If your bike falls over while running it could, and usually does, hit the throttle on the ground and revs the engine to max with no oil to the bearings because it's on it's side and it will destroy your engine instantly.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
