I First of all, I ain't no carb x'pert so take it for what its worth. I see you have a 78 model. Do you have the breather hoses connected to the airbox? Original configuration was to have two sets of T's for car pairs. One T was for air and one was for fuel. The upper hole is where the air T goes and the lower T is where the fuel T goes. OK, you probably don't have a problem with switching them by mistake. If you don't draw a vacuum through the breather hoses at high rpms, it can cause very rich conditions. Indy Rick found flooding conditions when a breather hose was plugged. Blane Hoops found that if the breather hoses are simply not connevted, overly rich conditions can occur. Hop that helps you out some.
Originally posted by strom
OK... some new info...
So, anybody who knows XS carb shrine, please HELP!
I noticed that under a bit higher revs, gas pours out of the hole on the right lower side on the back of each carb. What that hole does, is beyond me, but it floods the engine and whatever gas cant get there, runs to the airbox. I tried some K&N filters today after a carb session and I noticed my legs were sprayed with gas. Next I pulled the carbs again and blew some air with a compressor in the back side of the carb, and the piston thingie lifted and air-fuel mixture was sprayed out in front (I raised the front hatch-something-round thingies) and also gas came out of that hole in the rear (the right one). All four carbs do that.
Any ideas... don't be shy and help please!
LP
LP
