push start
  • b1rks
    • Nov 2006
    • 38
    • ontario can.
    push start
    batteries a little long in the tooth. curious correct procedure push start. Never done
    If the battery is too far gone, push starting may still not work. Once the voltage levels drops below a certain magic level, the TCI will not work properly to fire the plugs.
    Other than that, push starting should be much like it would be with any other 700 pound dead weight of a bike. Point it down a bit of a grade, get it rolling, hop on without tipping over, clutch in, pop it up into second, stand up on the pegs, drop your arse down and drop the clutch, hope it work the first time unless you have lots more downhill grade.
    Oh, you'll also want to have the key in, ignition turned on, kill switch set to run.
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      I once push-started my 56 Ford pick-up by myself. I was 17 at the time. Level parking lot to boot. Couldn't do it now. (wish I still had the truck).
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • Dsxs11
        • Jun 2007
        • 240
        • Millington, Michigan
        What was said with the addition of a "friend" make sure he's disposable or a really good friend. Use him for push power.
        I hate signatures. Too many cars and Bikes to list here.
        • pggg
          • 1609
          • NZ
          Push starting motorbikes, talkin' a whole science in itself, it's all in the timing, the old codgers round the place used to have it down to a fine art but unlucky the XS11 isn't a Triumph, Harley, Norton, Matchless, the old pommie bikes light enough to get rolling pretty quick, one compression stroke to lock the tyre, put it high gear and either drag the clutch as you run, big drag on the transmission and hard to get up to decent speed, or hit the seat, hit the footpegs, feather the clutch and tweak the throttle and hammer the gear lever into 2nd gear - all in one hit. Land on the seat side-saddle if you're cool with the balance, otherwise you're gonna have to leap upon the bike in one skilfull athletic movement while still performing all of the above. Up to it?
          • Crazcnuk
            • 2980
            • Hinton, AB, Canada
            In my experience, the Japanese 4 cylinders push start VERY easily. In fact, you may be caught off guard the first time you dump the clutch...
            I've push started GS1000, CB-750, Bonneville 750, and just a couple weeks ago, we push started a CB900C about a dozen times.
            Do not try and push start a VT1100 Shadow, unless you have a VERY long, VERY Steep hill, and use 4th gear.
            '05 ST1300
            • pggg
              • 1609
              • NZ
              They'll start very easily - the hard part is GETTING them to start very easily...
              • Crazcnuk
                • 2980
                All my bikes have always started very easily. Even the GT-750 with the blown crankcase seals.
                '05 ST1300
                • red bandit
                  • 951
                  • central michigan
                  A couple yrs ago I had a Yamaha 550 that I could push start standing along side it and not taking a step. I can't do that with the 11. But I do think the 11 push starts easily.
                  79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
                  79 SF parts bike.
                  • Snow
                    • Oct 2002
                    • 1041
                    • Tallahassee, FL
                    This past winter I had to push start my bike darn near every day...luckily it's old hat for other bikes for me. As long as I'm not going uphill, I can push start it - put it in neutral, turn on choke, turn ignition and kill switch on, run along side bike (will holding clutch pedal) , jump on bike and dump into 1st or 2nd.
                    • Crazcnuk
                      • 2980
                      First time we push started my friend's GS1000 we thought we were in for a tough push, after having tried to push the VT1100 a few times.
                      What happened was, we both started pushing, me behind and Ed off to the side. When he let the clutch out the bike took off, half dragging him around the parking lot. Luckyily, he managed not to fall over or hit anything...
                      Oh yeah, when push starting a bike, point it towards the empty part of the parking lot!
                      '05 ST1300
                      • renegade_xs11g
                        • 462
                        • Mid-Michigan
                        Mine stalled out at a light not long ago, my wife on the back, I paddled with my legs(I imagine myself looking very much like a large penguin) dumped the clutch after turning off the key, then turned it back on, to kill the headlight!
                        Very glad it started right up, wouldn't have been able to get enuf speed for another try
                        My Photo Bucket
                        • thewiz
                          • Oct 2006
                          • 1115
                          • Wilksboro, NC
                          dunno know the year ....
                          of your bike .... but both my 79s have kick start pedals stashed under and forward of the battery tray ... my 80 does not .... one more option, if you have it.
                          80G Mini-bagger
                          Past XS11s
                          • Eddie Gravy
                            • 51
                            • LA, ca. Seymour, IN. Remsen, NY
                            start me up
                            i've only tried once to kick start maha.
                            i'm about a buck seventy, need to gain another buck to be big enough to kick this bitch.
                            dont know what the removable kick pedal is like for the xs, got the bike with a kick pedal from a 79 superglide, its got a pretty long arm, figured it be easy.
                            dripping with sweat, i just pressed the start button.
                            push starting; do gears grind when dumping the clutch?
                            i hate that sound.
                            One of a kind SF
                            (Do not take advice from this man)
                            • Crazcnuk
                              • 2980
                              My first few bikes were all kickstart only. The first one I got that had electric was a '76 CB360T. Later my '78 CB750-4K had a tough time starting when it was below 0 outside, so I would crank the electric starter for 5-10sec, then kickstart it. It would start first kick doing it this way. Apparently it didn't have enough power to crank and spark, but it would at least get fuel in, so that a kick would give it the spark it needed.
                              "push starting; do gears grind when dumping the clutch? "
                              No, you should have the bike in gear before you start to push, with the clutch pulled in.
                              Some bikes are harder to push in gear, even with the clutch in. Those you have to push, the thenl in clutch, shift UP into 2nd, then let the clutch out, all in a second or two, but you should not be grinding any gears...
                              The higher the gear you can be in when you try to start the better.
                              '05 ST1300
