Pulling/splitting the engine
  • Crazcnuk
    • 2980
    • Hinton, AB, Canada
    Not the rear axle. It's too big. Any other ideas?
    '05 ST1300
    • AlanB
      • Oct 2006
      • 705
      • Scotland
      Hi Crazcnuk,
      Must be the front then, I am pretty sure something fits!........ I can't check on mine 'cos both spindles (and wheels!) are non-stock.
      AlanB
      If it ain't broke, modify it!
        • 7819
        It may be the bolt holding the swingarm. I also remember someone said one of the bolts fit. I have a tool, so I don't need to worry. I'll be taking down an engine in about a month. Time to start on the winter project!!
        • AlanB
          • Oct 2006
          • 705
          • Scotland
          Hi DiverRay,
          The thread on the stub pins for the arm is Real Big, and is a very fine thread.... So that does not fit!
          AlanB
          • Brian_D
            • 355
            • Gardner, KS
            Alan remembered correctly...but not sure why it didn't work.
            Here is the thread where Winterhawk gives the dimensions of the threads for the flywheel puller (M16 X 1.5 R.H.) and a link to a Motion Pro tool.
            Also, Here is the thread where Geezer suggests using the rear axle.
              I've just always used a cheap pulley puller. Just back the rotor bolt out a few threads and use the top of the bolt to tighten the puller against good and tight.. then give the puller a good whack with a hammer.
              • andreashweiss
                • 951
                I have taken many paperweights off by using a piece of old firehose and a big hammer. The shaft is tapered. Use several layers of the hose on top of the paperweight. Proceed to hit very hard with large hammer it should jar it lose.It usually just pops off. May sure you loosen the bolt first. Using the puller also works. Hammer method seems to work for me.
                • Crazcnuk
                  • 2980
                  I already knew it was an M16 fine thread. Unfortunately, my little town doesn't stock a pile of metric bolts.
                  I tried the axle bolt, it is too big.
                  I don't see the point of buying a tool, when a 90 cent bolt does the job. Remember the tool is even rarer than the bolt!
                  I can't find my puller, and we tried a friend's but his would not stay on the rotor, it just kept slipping off.
                  My rotor is NOT a paperweight. I don't want to damage it. I need it off to get the crank out of the crankcase.
                  '05 ST1300
                    When you've tore apart as many as Andreas, and you have those heavy bulky parts that no one ever buys because they don't break or wear out such as a rotor... you'd probably have a different view on them too.. lol. Paperweights, door stops, trot-line weights and rotors are all the same thing to him I'm sure! lol. OK.. as far north as he is, a trot-line is probably not one of the many uses, but you get the idea.
                    • Crazcnuk
                      • 2980
                      He says as I change a rotor on a CB900!
                      Apparently the DOHC Honda 4's had weak rotors that were the main cause of charging failure on those.
                      I assume your saying XS1100s don't have this problem as much?
                      '05 ST1300
                      • Crazcnuk
                        • 2980
                        I tried both axles, and anyother bolts I could find, none would take the rotor off.
                        Finally just got a metric bolt that fits.
                        '05 ST1300
