Bought my XJ 1100 in July of 2002 and one of the first things I did was change the oil and filter. Didn't have a repair manual at that time. Recently had to do so again because of the gas in oil problem. I noticed this time in my repair manual that there is supposed to be a spring and washer located under the filter. Obviously the PO lost it! I reinstalled the oil filter anyway after eyeballing the clearances between the block and the oil filter cover and it seems there isn't much room for a spring anyway. After the oil change and filter replacement I have ridden the bike about 200 miles with no apparent problems (no low oil pressure light or leaking). How important is the spring and washer (are they necessary?) and how available are these parts? Any input is appreciated.
Maxim4rob
'82 XJ1100
'82 Honda CM450 Custom
'97 Harley Sportster
Maxim4rob
'82 XJ1100
