Carb Bowl Gallery's
  • mro
    • 4276
    • Hayward, California
    3 sets?
    think I read some where (maybe in a tech tip) that ths XS11 uses one carb per cylinder and has for cylinders
    mro
    btw, with them that clean might consider one "Black set".
    Look pretty cool on my special.
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      Hey MRO ... Yes I have 3 sets of 4 carbs. The ones that came on my 1979F, The ones that came with the free 1979SF and a set I bough on ebay cheap. I still have one to clean and mount on that rack. Yes I may paint one set black for my hop up bike
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • saddle up
        • 165
        • Portland OR
        Has anyone tried using tip cleaners for a torch??
        If I knew I was going to live this long, I would have taken better care of myself..
        • 79XS11F
          • 3563
          Spray paint gun cleaning brushes are very similar. 4 tiny bottle brushes and a few different gauge stiff wires. That's what I used along with compressed air
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • frogdink
            • Feb 2007
            • 146
            • Richmond, Maine
            wow
            those carbs look amazing......whats your mailing adress?.........
            1982 XJ1100J
            Sold:
            1974 RD200
            1975 xs500
            1985 Honda XR350
            • 79XS11F
              • 3563
              DIFFERENT EMULSION TUBES On SAME CARB RACK ???
              OK so the 4th carb body is now cleaned and the rack is complete. all that remains is the jetting and i hit my first question ... I did not record where the emulsion tubes came from because I expected them to be all the same. That was not the case. I have 2 of one type and 2 of another. the difference is in the number of holes in the sides of the tubes. I am guessing that the 2 richer ones would go into #2 & #3 carbs?? More holes in the sides = richer ????
              Rob
              1978 XS500E
              1981 Suzuki GS1100
              • red bandit
                • 970
                • central michigan
                Yep, the 2 richer ones go to 2-3. The ones with LESS holes are richer, those holes are air holes.
                79 SF parts bike.
                • mitch
                  • Oct 2002
                  • 934
                  The Bowls
                  Don't throw those bowls out, Solder the holes up and find the right size bit and drill them out to the proper size. Then you are good to go !!
                  Doug
                  Doug Mitchell
                  82 XJ1100 sold
                  2007 Stratoliner 1900 sold
                  • 79XS11F
                    • 3563
                    Fair enough .. but what is the right size? I guess I could also fill the bottom with JB wield and drill it to the proper size once the size in known.
                    I am guessing that the stand pipe makes contact with that jets face?? If so the JB wield could maybe be applied through the hole at the bottom of the bowl
                    Rob
                    1978 XS500E
                    1981 Suzuki GS1100
                    • mitch
                      • Oct 2002
                      • 934
                      Bit
                      Find a bit that just fits in a good one then use a very small amount of solder get it real clean and hot with liquid flux . Then dab a little solder on it and drill it out
                      Doug
                      Doug Mitchell
                      82 XJ1100 sold
                      • pggg
                        • 1609
                        • NZ
                        Starter jets, go from .4mm on 78's to tiny .25mm on the 80's carbs(clymer manual), you'd need to drill then re-seal an access hole from underneath to get at the jet to solder and re-drill, a common .5mm drill bit would do it, it'll be richer than normal but what the hell it's only for starting, actually the starter circuit probably operates fine even with the jets drilled right out.. just use less lever?
                        • 79XS11F
                          • 3563
                          WOW .. thats TINY .. do they make bits that small?
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                            That looks like it should work, pggg. It looks like you could also drill a larger hole, say about 3mm, then use a fine drift punch to punch out the brass jet. You could solder and re-drill it where it is easy to get at, insert it back where it belongs, then plug up the 3mm hole.
                            • mason79
                              • Mar 2006
                              • 1359
                              • los angeles, ca
                              diff a work of art
                              History
                              85 Yamaha FJ 1100
                              79 yamaha xs1100f
                              03 honda cbr 600 f4
                              91 yamaha fzr 600
                              84 yamaha fj 1100
                              82 yamaha seca 750
                              87 yamaha fazer
                              86 yamaha maxim x
                              82 yamaha vision
                              78 yamaha rd 400
                              • thewiz
                                • Oct 2006
                                • 1115
                                • Wilksboro, NC
                                blinded by the light
                                maybe too late for these bowls, Rob, .... but a guitar string of the right guage is a pretty handy reaming tool (thx Prom) .... PLUS ... since I actually have more guitars than XSs (for now), strings are abundant here. If I were you though, I would try to get 'em a little more spotless .... .... oopps ... there's the oxymoron of the day.
                                80G Mini-bagger
                                Past XS11s
