yamaha part numbers ?
  • s head
    • May 2007
    • 32
    • australia
    kawasaki.com has site you can get OEM part numbers from,is there an similar site for yamaha?
    Bikebandit has the system but uses its own parts numbers.
    I need 2 new seals in my fuel taps,the round ones with 4 holes in them.
    thanks for any help
    Yamaha Parts
      Hey S Head,
      I found some Nitrile/Neoprene large rubber washers that were thick enough and was able to actually CUT MY OWN from one side of one, and used a single paper hole puncher to make the holes. I can't remember the thickness, but there are several thickneses to choose from at my local hardware store, you might find the same, and would be a lot cheaper!? JAT!
      • s head
        • May 2007
        • 32
        • australia
        thanks for that .I need to stop the taps leaking before I go any further with this bike .Its driving me nuts but I think you may be right top cat about pilot jet size.will check this when I get the
        carbs off again.
