Buy cheap get cheap results
  • confish04
    • Dec 2006
    • 52
    • Lancaster PA
    First off my name is Gerard & i`m a cheapaholic Well for the first time i got bitten bad with a cheap part (yea right) i was at the local bike shop & thought while i was there buying handle bars & grips for my 80 MNS , i`d ask about a set of fork seals. Well he had a set on the shelf (don`t know how long they were there) & asked how much . He said $16 bucks for the pair, i said sold , and i went on my merry way. Well i installed them last week with out a bit of trouble, until today. While i was on an errand i noticed the front end started to feel funny , so i looked down & found fork oil pissing all over everything Well got home & ripped it apart to find the right seal had fallen apart , so off i go to the local Yamaha shop this time & figured if i paid $16 for 2 it shouldn`t be so bad , i paid $36 bucks for 1 & Well after lookng at this new twice the price part i noticed it being a much better quality than what i had put in the first time. So now i`m waiting for the left one to fail so i can do this job again . So don`t be a cheapaholic & buy the best the first time
    Gerard
    04 Roadstar (starglide)
    80 midnight special
    • 1811
    Brings up an interesting question
    Gerard,
    Sorry to hear about your problems, but it does bring up an interesting question.
    I see seals listed on Ebay all the time for about the same price you paid for the set that fell apart.
    Does anyone have any experience with these seals and if so have you had good or bad results with them?
      I've heard several people say that the OEM seals are the only ones to buy. Dale_1 said he had good luck so far with the aftermarket ones... but that is seriously the only person I've heard say that so far. I'm sure there's others that have also... but I bet there's lots more bad luck stories to them than good.
      • confish04
        • Dec 2006
        • 52
        • Lancaster PA
        Re: Brings up an interesting question
        Originally posted by cajun31
        Gerard,
        The same ones seen on abay with the green pacage back ground are the ones i bought. I guess when it comes to rubber seals the factory is the way to go
        Gerard
        80 midnight special
          • 5050
          Re: Re: Brings up an interesting question
          You must know the brand! We can't just go around avoiding the color green.
          Gerard
          • yadada
            • 150
            • Louisburg, KS
            I've got 8k on a pair from Parts n More. No problems yet. Now where is some wood to knock on?
            Randy
            "I didn't break it! IT FAILED!"
            '82 XJ1100 "yamama"
            '09 Buell Ulysses
            '01 HD softail std - crunched
            • Snow
              • Oct 2002
              • 1041
              • Tallahassee, FL
              I've had the 'Leak Proof' ones fail on me within a few months and haven't had one single problem with the oem's I've installed. OEM's are available at the dealer or bikebandit.com for about the same price you paid for those seals at the shop.
              • Jerry
                XS & TRUE XJ GURU
                • 3023
                • Elma, IA.
                Also check past threads; there are some incorrect application charts out there. Most models with the leading fork (axle in front of the fork leg instead of through it) use a slightly (about 1mm IIRC) larger seal (inner and outer) than the others. Doesn't sound like much, but makes a big difference.
                Jerry Fields
                '82 XJ 'Sojourn'
                '06 Concours
                My Galleries Page.
                My Blog Page.
                • mason79
                  • Mar 2006
                  • 1351
                  • los angeles, ca
                  yeah if something cheap requires extensive labor and effort to get to, i normally don't skimp and get the best, the time to redo it isn't worth it.
                  especially if in involves the posibility of dropping the bike which in the case of fork off, that may apply...
                  History
                  85 Yamaha FJ 1100
                  79 yamaha xs1100f
                  03 honda cbr 600 f4
                  91 yamaha fzr 600
                  84 yamaha fj 1100
                  82 yamaha seca 750
                  87 yamaha fazer
                  86 yamaha maxim x
                  82 yamaha vision
                  78 yamaha rd 400
                  • Snow
                    • Oct 2002
                    • 1041
                    • Tallahassee, FL
                    Yeah, forks aren't something to play around with like that... a bad fork seal was 1/3 responsible for me almost dying a few years back...the other 2/3's was other stupid stuff...minimize risk, live longer.
                    • 79XS11F
                      • Jul 2006
                      • 3563
                      • Ottawa, Ont. Canada
                      I have always bought OEM parts if and when they are available. It's the only way to go given that the parts are for use on a high performance vehicle
                      Rob
                      KEEP THE RUBBER SIDE DOWN
                      1978 XS1100E Modified
                      1978 XS500E
                      1979 XS1100F Restored
                      1981 Suzuki GS1100
                      1983 Suzuki GS750S Katana
                      1983 Honda CB900 Custom
                      • confish04
                        • Dec 2006
                        • 52
                        • Lancaster PA
                        Re: Re: Re: Brings up an interesting question
                        OK the green package was from Vesrah part # AR-3702 They felt good & the left leg SO FAR isn`t leaking (so far)
                        80 midnight special
                        • thewiz
                          • Oct 2006
                          • 1115
                          • Wilksboro, NC
                          jackin' up ...
                          my F today to do the same job .... bought the seals from a local bike shop for 7 bucks a pair. They came in a Parts Unlimited package, made in Italy, brand name looks like NTK??
                          Long as they fit, I'm gonna' use 'em, but I'll watch closely .... like I think Snow is saying, that front end gets pretty squishy/scary with bad seals and no oil in there .... and overall handling just plain sucks.
                          80G Mini-bagger
                          Past XS11s
                          • confish04
                            • Dec 2006
                            • 52
                            • Lancaster PA
                            Hope you fair better than i did. Who knows maybe it was one in a million (i think i`ll play the lottery)
                            80 midnight special
                            • snowdog51
                              • May 2006
                              • 348
                              • st. paul ,mn
                              fork seals
                              everybody that works on bikes for money
                              knows aftermarket seals suck the only way they dont'n leak is if you don't put in fork oil.
                              as ever bill
                              ps don't ride faster than your sweet angel can fly.
                              bill hane
