okay i need help, thanks in advance,
i have this nagging preignition, or pinging that i can't get rid of.
engine is tune very well, sync'ed, valves checked, in spec, timing i retared a few degrees to address this issue with nominal affect.
i experimented with grades of gas and have been on high test indefinately.
only on loads like gunning it from 80 to 100 mph i can hear it ping , i have had this since day one, since i got the bike, the compression is 175 across the board,
is it carbon buildup? i see the base metal on the piston tops.
what is the remedy? retarded it till it stops, it wouldn't bother me.
thanks
thanks
