preignition
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    preignition
    okay i need help, thanks in advance,
    i have this nagging preignition, or pinging that i can't get rid of.
    engine is tune very well, sync'ed, valves checked, in spec, timing i retared a few degrees to address this issue with nominal affect.
    i experimented with grades of gas and have been on high test indefinately.
    only on loads like gunning it from 80 to 100 mph i can hear it ping , i have had this since day one, since i got the bike, the compression is 175 across the board,
    is it carbon buildup? i see the base metal on the piston tops.
    what is the remedy? retarded it till it stops, it wouldn't bother me.
    thanks
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
  • randy
    • Dec 2003
    • 4521
    Mason,
    May be running a little lean? I had that problem with my '81SH, move the needles up with washers and pinging went away.
    Your 79 has three notches on the main jet needles, try moving the clips down one notch.
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      thanks randy, they are in the middle position, and everything is stock exhaust, air box with foam uni filter,
      plz no, don't make me go into the carbs, i have never even tried to change needles postions just looked at it.
      i will take this into serious consideration and thank you randy...
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • randy
        • Dec 2003
        • 4521
        Well, there you go, the UNI filter will lean it out a bit. Have you tried a stock air filter?
        • mason79
          • Mar 2006
          • 1359
          • los angeles, ca
          would colder plugs make up the diff?
          never ran with the k and n
          k and n shrunk after washing so i went to uni,
          no experience with stock.
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
          • mro
            • 4276
            • Hayward, California
            ping/knock
            I've been experimenting with my 80G as it is rather noisy when accelerating. First have tried raising fuel level in float bowl. This has cut down the noise by about half, but bike does not have the power it should. Next plan to change main jets up one size to see if that will do it and still have all the power it should. If that helps may try changing 2 & 3 another size up.
            Possible that CA CA land bikes run a little leaner. Our politicians have a history of fixing things until they are truly broke.
            mro
            • mason79
              • Mar 2006
              • 1359
              • los angeles, ca
              i thought e and f model did not have california specific models and the jetting are the same 50 states.
              History
              85 Yamaha FJ 1100
              79 yamaha xs1100f
              03 honda cbr 600 f4
              91 yamaha fzr 600
              84 yamaha fj 1100
              82 yamaha seca 750
              87 yamaha fazer
              86 yamaha maxim x
              82 yamaha vision
              78 yamaha rd 400
              • planedick
                • Mar 2005
                • 2068
                • Yorba Linda, California
                Answers...
                Your high compression is because of carbon deposits. What you see when looking in the spark plug hole isn't representative of what's in the cylinder. That area is always cleaner because it's right where the ignition starts and is hottest and burns best. I think you should run some seafoam through it to get rid of some of the carbon build up. BTW, needles can be adjusted without removing the carbs.
                Drilled airbox
                Tkat fork brace
                Hardly mufflers
                late model carbs
                Newer style fuses
                Oil pressure guage
                Custom security system
                Stainless braid brake lines
                • Incubus
                  • 1003
                  • Austin TX
                  Don't be afraid of disassembling the carbs, Mason. I've had mine apart about 50 times in the last few months. After the first 25 or 30 times you can do it in a foxhole under fire at night. It's not that hard. You just have to pull the top covers to get to the needles. You don't even have to take them off the rack.
                  Patrick
                  XS11F (Incubus, daily rider)
                  1969 Yamaha DT1B
                  • mason79
                    • Mar 2006
                    • 1359
                    • los angeles, ca
                    believe me my first experience was gas comeing out of the airbox and i had to triple clean them a thousand times, not to mention trying to rejet for some intake and exhaust changes, and back again...
                    you make it sound like you like to take them apart, well i wouldn't mind if there wasn't gasoline involved i just hate that smell and stinging and getting all over the place, mostly.
                    okay i'll get to the needles...
                    History
                    85 Yamaha FJ 1100
                    79 yamaha xs1100f
                    03 honda cbr 600 f4
                    91 yamaha fzr 600
                    84 yamaha fj 1100
                    82 yamaha seca 750
                    87 yamaha fazer
                    86 yamaha maxim x
                    82 yamaha vision
                    78 yamaha rd 400
                    • mason79
                      • Mar 2006
                      • 1359
                      • los angeles, ca
                      thanks randy,
                      that was it, you gave me a new bottom, mid and top end, esentially a new bike, who knows which xsive was not realizing the bike's true performance potential by shoddy tuning or neglect again a millions thanks,
                      power plays such a large role in the handling of the bike as well.
                      now i really need a new clutch
                      History
                      85 Yamaha FJ 1100
                      79 yamaha xs1100f
                      03 honda cbr 600 f4
                      91 yamaha fzr 600
                      84 yamaha fj 1100
                      82 yamaha seca 750
                      87 yamaha fazer
                      86 yamaha maxim x
                      82 yamaha vision
                      78 yamaha rd 400
                        • 5061
                        What was "it?" Raising the fuel in the bowls or raising the main needle or stock filter?
                        Originally posted by mason79
                        thanks randy,
                        • mason79
                          • Mar 2006
                          • 1359
                          • los angeles, ca
                          raised the needle one notch
                          History
                          85 Yamaha FJ 1100
                          79 yamaha xs1100f
                          03 honda cbr 600 f4
                          91 yamaha fzr 600
                          84 yamaha fj 1100
                          82 yamaha seca 750
                          87 yamaha fazer
                          86 yamaha maxim x
                          82 yamaha vision
                          78 yamaha rd 400
