out of no f***ing where
  • Eddie Gravy
    • 51
    • LA, ca. Seymour, IN. Remsen, NY
    i'm going straight for the carbs for this one.
    maha drives wonderfully. starting the bike up after work, would just die, back fireing pops and hissing, got her going high rpm, anything diping around 3 grand would kill her.
    hard to start, when she starts she goes for 5 seconed then dies, above 3.5 grand she'll stay running.
    i dont know how to search other forums for this info. im going at the carbs. i'll look over electrical while im ditry, look for shorts or groundouts.
    any suggestions?
    had 7" to 8" flames of fire out of my turnout mufflers(oval dia 5"), visually: ****ing cool. really: maha was screaming.
    One of a kind SF
    (Do not take advice from this man)
  • audijunky
    • Apr 2006
    • 707
    • VA
    Sounds like idle circuit on your carbs
    I think your guess would be right.
    Time to take em off and clean em
    79 XS1100 modified standard
    straight pipe 4-2 exhaust
    Owned 83 Honda V65 Magna
    Owned 02 Vstar 650 classic
    owned 85 Honda Shadow VT 700C
    • mro
      • 4276
      • Hayward, California
      Is that with the enricher/starter circut pulled out (choke)
      Does sound like a fuel/dirty carb problem.
      Back fires sometimes pop off the caps on the carb boots.
      At main forum page scroll down to the "Maintenance" section
      good info for cleaning/adjusting carbs
      mro
      • audijunky
        • Apr 2006
        • 707
        • VA
        Is the inside of your tank rusty/dirty?
        Do you have inline fuel filters and if so are they clean?
        Dirty gas could cause an issue
        • 80mdnt11
          • Mar 2006
          • 221
          • S.E. IL./ Olney
          flames!
          Haven't seen that on anything I've owned since my '67 Chevy short-bed!! 302 small block, High rise, 650 dbl. pumper, .490 solid lift, headers & yes burnt out glass packs!! Ahhhh, the memories!! 6-7000 & side step the Muncie 4-speed! Whooooo
          Believe youre on the right track, just a-bit lean.
          This site is Great!! You can find infinite info on the XS11 here!!
          "Elvira"
          '80 XS1100LG
          • goldcoastguy001
            • Dec 2006
            • 137
            • Gold Coast, Australia
            Gueeeeeeeeeeze....clean your idle jets already.......!!!!!!!!!!!!
            1982 XS1100R
            1982 XJ650
            1983 VT400
            1990 XVS Shadow
            1983 Z1100
            -I just love the look on their faces when you leave them standing in the dust after they've lined you up on your XS.
            • JWSanders
              • 879
              • White House, TN
              While I'm always up for frolicking through the carburetors on a nice day, I'd still consider a portion of a can of seafoam before a big teardown. That stuff works wonders.
              If you have rust in the tank, it wont help though.
              80 XS1100SG
              81 XS400SH
              Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
              A Few Animations I've Made
              • Eddie Gravy
                • 51
                gonna have to drill, yuck
                first thing; i hate brass.
                striped the air pilot jet (48.) on the number 2 carb, gonna have to drill it out.
                ive drilled bolts that if i screw up i can tap. dont think i have the option to re-tap.
                any recomendations other than, carefull? haha
                no noticable clogs on the jets, any of them? i recant, one slowed down hole in a pilot jet (19.of carb 1), but not clogged.
                did have an amout of black soot in the 2 and 3 (butterfly side) and on the bottom of diaphram cylider (lack of a word for the can under the diaphram).
                obviously the back firing into the carb? maybe.
                still to blow out carbs, but then my theory of a clog jet is out the window. what am i not looking at?
                also what is the name of the black sealant around the diaphram, will need to purchase. or does the diaphram need a sealant?
                Drilling Fock!
                One of a kind SF
                • Eddie Gravy
                  • 51
                  ha
                  3 out of 4 polit screws (31.) were already broken off, i guess than might not help.
                  One of a kind SF
                    You can use RTV Ultra Black, or plasti dip.
                      P.S. Use only to patch holes. Don't get carried away!
                      • Eddie Gravy
                        • 51
                        not looking to patch holes, just seal the gasket in its seat.
                        but at least there's multiple applications for the product.
                        One of a kind SF
                          The gasket? The diaphragm? No sealant is necessary for the diaphragm for the slide or any diaphragm for the vacuum control petcocks.
