Guru Question
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    Guru Question
    I'm putting new HD Vesrah clutch springs in, and in the process removed the kickstarter mechanism (Blue circle)....I have never had to use it and probably won't. Question is the Gear wheel that normally sits here in the Red Circle, Do I or can I remove it or just leave be?.....Looks like T.C. Completely removed his....Thanks in advance.....
    MDRNF
    79F.....Not Stock
  • mro
    • Oct 2005
    • 4276
    • Hayward, California
    In or out, should not make any difference other than having to split the cases should you latter decide you want the kick starter back.
    mro
      Hey Chop,
      Mine's an 81SH, it came that way from the factory!
      It looks like there's a set of bolts that hold it in place, so you might/should be able to remove it!
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        dead weight
        the KS mechanism is about a pound or so...I was just wanting to know if I can remove the rest of the mechanism without having to split cases?
        MDRNF
        79F.....Not Stock
          It will be fine without the kickstarter, but you'l get rid of much more weight from the whole assembly coming out.. but you will have to split the cases for that. You'll either need a cover with a plug, or buy one to cover up the hole the shaft went through in the sideplate.
          AND..... That wire that the red arrow is pointing to. It will make life much easier if you don't mess with that! lol. I think it was TC who can vouch for that.
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            splittin it
            well thanks, I won't mess with the opposite gear then, just leave out the kickstarter part that goes thru the cover.I have a custom cover that the shaft hole has been welded up with alloy....thanks for the info....chop
            MDRNF
            79F.....Not Stock
            • MAXIMAN
              • Jan 2005
              • 1817
              • As far from the government as humanly possible.
              Chop
              There's a BETTER way to loose a few pounds on your Eleven...
              It's called...
              A GYM!
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                gyminy geez wally
                I go to the gym when I'm not out on the 11...sometimes I take it to the gym with me, do a workout hit the shower and blow dry on I-35
                MDRNF
                79F.....Not Stock
                • MAXIMAN
                  • Jan 2005
                  • 1817
                  LMAO!
                  Yeah I know you are in good shape. Just giving you the bizness.
                  I burnt a guy on a Gixxer1000 while I was on my ZRX. He caught up with me at a gas station and said he thought his bike must weigh more than mine. I flipped up my face shield, smiled and gently responded "It does with you on it." When I rode off I could see him in my rearview with a dumbfound look like a cow gazing at a passing car.
                  • xschop
                    • Feb 2006
                    • 1794
                    • oklahoma city
                    ooooooooouuuuuucccccccccchhhhhh!
                    truth hurts at times.....that is very funny too see a BIG guy on a rice rocket with plumbers ass....I think they should just get a tatoo and a Harley....
                    MDRNF
                    79F.....Not Stock
                    • xschop
                      • Feb 2006
                      • 1794
                      • oklahoma city
                      No thread Jacking....... Max
                      I'm outta here, Can't spend my vacation time at a key board, gotta go work on "PePe"
                      MDRNF
                      79F.....Not Stock
                      • Snow
                        • Oct 2002
                        • 1041
                        • Tallahassee, FL
                        Originally posted by trbig
                        I
                        Yeah....I can vouch for that also!
                        • xschop
                          • Feb 2006
                          • 1794
                          • oklahoma city
                          finished
                          Got it all put back together and she no longer slips under hard acceleration in 3rd or 4th (before 750 Fd mod it would slip in 5th at times).....The Vesrah springs are hardcore and give alot more bite. Also I mic'd the friction discs all @ 2.9mm. They were nasty Black, so I Dipped them in 20% Sodium Hydroxide Soln.for 10 min and the discs look brand new (chemistry's cool and I'm lazy, no sandpaper here) I am going back with the Castrol 20-50 after seeing so many positives about this Brand and weight....
                          MDRNF
                          79F.....Not Stock
                          • MAXIMAN
                            • Jan 2005
                            • 1817
                            Chop
                            Great idea using NaH! I hope you rinse them off afterwards. That stuff is corrosive.
                            Another very good oil for these machines I've found is Valvoline 20w-50 4 stroke motorcyle oil. It is designed for wet clutches and works very very well for air cooled engines especially in the heat of the summer. And ...and...it's widely available. I have seen it in every NAPA store I've been in from here to west Texas to Nevada.
