Anyone done this before?
For your consideration/comments
Hi...my name is Mike, and I'm a lane-splitter.
'80 XS1100SG (mine)
'87 CMX450C Rebel (daughter's first bike)Tags: None -
Wow, sounds like that guy had some great luck with cleaning out the carbs. The problem that I've found is that you can't assume how well someone has cared for a bike or how long it has sat. Carburetion has its pros and cons and unfortunately letting them sit for any length of time is never a good policy.
My thought would be try it if you think that it will help you. Depending on the chemical content, you should be cool to run it and see what happens. Let us know if you try it.
Good luck! -
Hey Mike,
Well, it is interesting that he was able to get it to run on pure carb cleaner, but I don't think it's necessary. He was just wanting INSTANT gratification!
I run several ounces of SEA FOAM every few fillups. He should have put about a 1/2 can in a tank of gas, and run it about half empty, then let it sit a day or so, run the rest of it out, etc.! Just like it eventually did, the cleaner was able to dissolve the varnish/gum from the circuits, but probably would have anyways with more time at a lesser concentration which would be safer for the rubber carb parts!
T.C.T. C. Gresham
